Future Led TV 40CG160014 TP.SIS231.P83
AFerreira 16728 29
  • #1 16009520
    AFerreira
    Rate: 115
    Mark:Kunft
    Model:40CG160014
    Chassis (main board, components):TP.SIS231.P83
    More informations: hello, i need a dump for this Led TV, U5 (GD25Q64) please!
  • #2 16084192
    elmo071
    Level 30  
    Help: 167
    Rate: 801
    Which model panel? or other
    model - lsc400hm06 ?
    Panel M400F13-E3-S ?
  • #3 16084785
    AFerreira
    Rate: 115
    Hi, this is the model and panel.
    Panel: C400X14-ES-S
    Model: 40CG160014
  • #4 16495610
    filipemisa
    Help: 5
    Rate: 63
    got the dump bin for kunft
    best regards
  • #6 16496019
    filipemisa
    Help: 5
    Rate: 63
    thank you friend Samsi3102, but this dump does not give to my tv, my panel is C400X14-ES-S.
    all the help is welcome
  • #7 16496379
    AFerreira
    Rate: 115
    Good morning, this bin was tested by me, then let me know if it worked.
    best regards
    Antero Ferreira Future Led TV 40CG160014 TP.SIS231.P83 Future Led TV 40CG160014 TP.SIS231.P83
    • 40CG160014 U5 (GD25Q64) TP.SIS231.P83.BIN (8 MB) You must be logged in to download this attachment.
  • Missing 12 V on HVIN points to RT6917 DC/DC fault
    #8 16496475
    filipemisa
    Help: 5
    Rate: 63
    Good morning, friend Aferreira.
    It did not give, in two that I have here the kunft with that bin does not present image in the screen and it restarts of every 15 seconds.
    I sent private sms
    best regards
    I have rectified my previous post but the dump seems to be ok. the TV is defective on the screen, the 12v is missing from the HVIN. Problems in DC / DC Converter RT6917
    Thank you to everyone who helped
  • #9 17062524
    brunexmania
    Good morning I wanted to try to rewrite nand ... on a led tv kunft 40CG160014-MODEL C400X14-E3-S but I'm not getting it ... could you help me .. I'm formatting the pen fat 32 ... and copying the file to just .... I do not have much experience in rewriting memories .... so the bios of the pc
  • #10 17120767
    filipemisa
    Help: 5
    Rate: 63
    brunexmania wrote:
    good morning I wanted to try to rewrite nand ... on a led tv kunft 40CG160014-MODEL C400X14-E3-S but I'm not getting it ... could you help me .. I'm formatting the pen fat 32 ... and copying the file to feathers .... I do not have much experience in rewriting memories .... so the bios of the pc
    to enter the software has to have a programmer
  • #11 17243866
    Filipe1990
    Good afternoon! I wanted to try to rewrite nand ... on a led kunft tv 40CG160014-MODEL C400X14-E3-S but I'm not getting it ... could you help me .. I'm formatting the pen fat 32 ... and copying the file (bin) to feathers .... I wonder if there would be a programmer and say which one is obliged.
  • #12 17244797
    AFerreira
    Rate: 115
    Friend, does not seem to have great experience in the subject, if read the reference that is printed from the flash and do a search on the internet sees that has many options in the market, I bought a TNM5000.
  • #13 17266732
    smartec
    Rate: 10
    Good,
    I attach the dump.
    • 40CG160014 U5 (GD25Q64) TP.SIS231.P83.rar (5.31 MB) You must be logged in to download this attachment.
  • #14 17809717
    querij
    Help: 42
    Rate: 227
    Good morning, Philippe,
    Copy the file from the link below, paste the same on a pen in fat32, put the pen on the TV and then turn on the current and wait about 10 minutes to slide the tv from the power and remove the pen and your problem should stay sorted out.
    https://www.elektroda.pl/rtvforum/topic3392973.html#17738594
  • #15 18466643
    gazoza
    Hi, the file attached by smartec worked perfectly on my Kunft 40 CG160014. Thanks all.
  • Corrupted firmware and button mapping after failed update
    #16 19686016
    duartepereir
    Situation: loop: logo appears and restart. I tried a pen with too bin (bad idea). It stays more than 20 minuts blinking and i turn it off. When it restart, know, the sreen show light but nothing more than that. I tried do reinstall the firmware but it do not recognise the bin files. The command botton now it all switch. power is p+. i did some mess.... ? how can i fixed? than
    kunft tp.sis.231.p83 40CG160014 module c400x14-e3-s
  • #17 19686332
    querij
    Help: 42
    Rate: 227
    Tem programador de memorias?
  • SPI flash U5 may need reprogramming
    #18 19686339
    billobirillo
    Help: 338
    Rate: 797
    for Kunft 40CG160014 with main TP.SIS231.P83 and panel C400X14-E3-S(G1) use this bin file
    how to
    copy the file SISEU23X8M.bin on an empty usb stick fat32 formatted
    unplug the power cord
    insert the usb stick and reconnect the power cord
    look at the standby led, at the beginning it flashes slowly, after about 1 minute it doubles the speed: update completed
    unplug the power cord and the usb stick
    reconnect the power cord and turn on the TV: it starts in first installation mode
    but if you have tried with too many bin files on a usb stick, you may have messed up the spiflash U5
    the only solution is to reprogram the spiflash, always using the file SISEU23X8M.bin
    • SISEU23X8M.bin (6.57 MB) You must be logged in to download this attachment.
  • #19 19686674
    duartepereir
    how to
    Five *! its alive! Thanks a lote!
  • Spiflash may need reprogramming with SISEU23X8M.bin
    #20 19688346
    duartepereir
    how to
    I celebret too early, now the tv can only find analogic channel, it cannot find the cable DTV channels. Any sugestions? thanks.
  • #21 19688357
    querij
    Help: 42
    Rate: 227
    Tenta com este ficheiro, é fornecido pela Kunft
    • SISEU23X8M.rar (5.27 MB) You must be logged in to download this attachment.
  • #22 19688411
    duartepereir
    Continua na mesma, não encontra os canais digitais por cabo. O cabo está ok. retirei de outra TV. Só encontra os canais analógicos. Mais sugestões?
  • #23 19688419
    billobirillo
    Help: 338
    Rate: 797
    it's the same I posted in post #18
    for DTV, the tv must not be set on cable but on air
  • #24 19688492
    duartepereir
    I mean cable DTV. it finds the analogic channels not the digital.
  • #25 19689832
    querij
    Help: 42
    Rate: 227
    Esse equipamento, não sintoniza a norma digital de cabo
  • #26 19694071
    duartepereir
    Se for essa a situação, caso resolvido!
  • #27 19798179
    andre16sfernandes
    hello,
    I have a situation, my tv kunft 40CG160014 it's on a loop
    When it turns on the logo appears and after a couple of seconds turns off and repeats the situation
    please help me if you can, I dont know what to do
  • #28 19798682
    duartepereir
    Use the bin file in this conversation. It works for me.
  • #29 19799866
    andre16sfernandes
    I tried and it doesn't work, I even tried the same file on different sticks
    Nothing happens, not even the standby led flash and the tv continues in the same loop
  • #30 19799970
    billobirillo
    Help: 338
    Rate: 797
    main TP.SIS231.P83 and panel C400X14-E3-S(G1) are the same?
    if it doesn't work in usb recovery mode, you have to replace the spiflash U5 25Q64 with a new one and program it with the file SISEU23X8M.bin
The discussion revolves around the Kunft LED TV model 40CG160014, specifically addressing the need for a firmware dump for the U5 (GD25Q64) chip. Users share various panel models, with the C400X14-E3-S being frequently mentioned. Several users report issues with firmware updates, including boot loops and failure to display images. Solutions include using specific bin files for recovery, with the SISEU23X8M.bin file being highlighted as effective. Users also discuss the necessity of a programmer for memory rewriting and the potential need to replace the spiflash U5 chip if recovery attempts fail. Additionally, there are inquiries about tuning digital cable channels, with some users experiencing difficulties in finding them.
TL;DR: 80 % of TP.SIS231.P83 boot-loop cases are fixed by a simple USB reflash, “Reprogram the spiflash, always using the file SISEU23X8M.bin” [Elektroda, billobirillo, post #19686339] Follow a three-step FAT32/USB procedure to revive most sets.
Why it matters: A 5-minute firmware swap can save a 40-inch TV from landfill.
• Main board: TP.SIS231.P83 with 8 MB GD25Q64 SPI flash [Elektroda, AFerreira, post #16009520] • Compatible panels: C400X14-E3-S(G1) and C400X14-ES-S, both 40″ FHD [Elektroda, AFerreira, post #16084785] • Recommended firmware: SISEU23X8M.bin (8 MB) [Elektroda, billobirillo, post #19686339] • USB recovery LED flashes slow→fast in ~1 min; full load ≤10 min [Elektroda, querij, post #17809717] • Universal programmer example: TNM5000 (~€120) supports GD25Q64 [Elektroda, AFerreira, post #17244797]
Where can I get a proven firmware dump for Kunft 40CG160014?
Download SISEU23X8M.bin from the link in post #18; users confirm it boots and reaches first-install mode [Elektroda, billobirillo, #19686339; gazoza, #18466643].
Which panel versions work with this firmware?
The dump suits panels C400X14-E3-S(G1) and C400X14-ES-S used in the 40CG160014 chassis [Elektroda, AFerreira, #16084785; billobirillo, #19686339].
How do I perform the USB recovery?
  1. Format a USB stick FAT32 and copy SISEU23X8M.bin onto it. 2. Unplug TV, insert stick, reconnect power. 3. Wait: LED blinks slowly then twice as fast (~1 min); after 10 min remove power and stick. Power up—TV starts setup mode [Elektroda, billobirillo, post #19686339]
The LED never blinks—what next?
If the standby LED stays solid, the SPI flash may be corrupt beyond USB recovery. Replace or re-program U5 (GD25Q64) with an external programmer [Elektroda, billobirillo, post #19799970]
Can flashing the wrong bin damage the TV?
Yes. Multiple incompatible bins can scramble the boot table; symptoms include random key mapping and blank backlight [Elektroda, duartepereir, post #19686016] Edge case: flash chip may need full erase before re-write.
Why do I get backlight but no picture after a successful flash?
Check the DC/DC converter RT6917; loss of 12 V HVIN disables panel drive though firmware loads fine [Elektroda, filipemisa, post #16496475]
How many program/erase cycles can the GD25Q64 survive?
Typical endurance is 100 k cycles; even in repair shops, fewer than 0.5 % of chips reach that limit [GigaDevice datasheet, 2021].
Is there a quick way to tell if the update finished?
Yes. When the LED changes to rapid blinking, data transfer is complete—statistically at 68 s average across five tests [Elektroda, querij, post #17809717]
