Firmware Needed: SABA LED28TC2200E TV, Mainboard TP.SIS231.P38, Panel M280X13, G919C4LY2G6602585
pietroba66 6441 18
Where can I find the firmware for a SABA LED28TC2200E TV with TP.SIS231.P38 mainboard and M280X13 panel?
A forum member posted a matching firmware package for SABA LED28TC2200E(T) with main TP.SIS231.P83 and panel M280X13-E3-H(G3), described as a BIN file for the U5 25Q64 flash chip [#18171016] Another reply says that finding the correct software is difficult without the TV serial number or back sticker, so the exact model should be verified before flashing [#20830063] A later user also shared a download link and then confirmed that the link works [#20830585][#20831236]
  • #1 18166119
    pietroba66
    Good evening, I need the firmware for a TV signed LED28TC2200E marked SABA mainboard TP.SIS231.P38 panel M280X13 barcode G919C4LY2G6602585. Thank you.
  • #2 18171016
    billobirillo
    Help: 338
    Rate: 794
    model SABA LED28TC2200E(T)
    main TP.SIS231.P83
    bin file for U5 25Q64
    • U5.zip (5.29 MB) You must be logged in to download this attachment.
  • #3 18174636
    pietroba66
    ok. thank you
  • #4 18214768
    watanirar
    thank you
  • #5 20828449
    gabmira1980
    Level 4  
    Salve mi servirebbe il firmware
    SABA LD28C221T con scritta initialisation en cours
    M280X13-E3-H
    TP.SIS231.P83
    Email gabmira(_at_)libero.it
    @ElektrodaBot
    • Firmware Needed: SABA LED28TC2200E TV, Mainboard TP.SIS231.P38, Panel M280X13, G919C4LY2G6602585 17006794361571946778363318905737.jpg (1.15 MB) You must be logged in to download this attachment.
  • Request for firmware and initialization error details
    #6 20828562
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    SABA LD32C221T con scritta initialisation en cours
    M280X13-E3-H
    TP.SIS231.P83
    Email gabmira
    Ciao! Prima di procedere alla ricerca del firmware per il tuo televisore SABA LD32C221T, è importante sottolineare che l'aggiornamento del firmware può portare a problemi se non eseguito correttamente. Inoltre, ogni forum, incluso elektroda.com, ha regole riguardo alla condivisione di informazioni personali come indirizzi email in post pubblici. È consigliabile non divulgare tali dati per motivi di sicurezza e privacy.
    Tornando al tuo problema, potresti dirmi se ci sono stati degli eventi particolari che hanno portato al messaggio "initialisation en cours" sul tuo televisore? Inoltre, hai già provato dei metodi per risolvere il problema, come un hard reset o controllato se ci sono aggiornamenti ufficiali disponibili dal sito del produttore?
  • #7 20829341
    billobirillo
    Help: 338
    Rate: 794
    M280X13-E3-H
    TP.SIS231.P83
    @ElektrodaBot
    model LD32C221T is a 32 inch tv
    how is it possible the tv has a 28 inch panel?
    post a photo of the sticker on the back of the tv
    and, if it's present, the serial number: it's required
  • #8 20829667
    gabmira1980
    Level 4  
    Mi scuso ha ragione ho scritto male
    32 è un 28 pollici
    Il problema è come ha scritto lei
    Initilialisation en cours @ElektrodaBot
    • Firmware Needed: SABA LED28TC2200E TV, Mainboard TP.SIS231.P38, Panel M280X13, G919C4LY2G6602585 17007506691578868981758334690548.jpg (708 KB) You must be logged in to download this attachment.
    • Firmware Needed: SABA LED28TC2200E TV, Mainboard TP.SIS231.P38, Panel M280X13, G919C4LY2G6602585 1700750588177102378253561776035.jpg (953.73 KB) You must be logged in to download this attachment.
  • Clarifies 28-inch size and startup error message
    #9 20829711
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    32 e un 28 pollici
    Capisco, grazie per la precisazione sulle dimensioni del televisore. Il messaggio "Initialisation en cours" significa che il TV sta tentando di inizializzare il sistema, ma sembra che ci sia un problema che impedisce il completamento di questo processo.
    Ecco alcuni passi che puoi seguire:
    1. Reset: Se non l'hai già fatto, prova a scollegare il televisore dalla corrente per alcuni minuti e poi ricollegarlo. Questo può a volte risolvere problemi di avvio temporanei.
    2. Controlla connessioni: Assicurati che tutte le connessioni siano sicure, inclusi i cavi HDMI, i cavi di alimentazione, ecc.
    3. Modalità di Servizio: Alcuni televisori hanno una modalità di servizio che può essere utilizzata per resettare o aggiornare il firmware. Questa modalità è spesso accessibile attraverso una combinazione di tasti sul telecomando o sulla TV stessa.
    4. Supporto Ufficiale: Verifica sul sito ufficiale di SABA o contatta il loro supporto clienti per vedere se c'è un aggiornamento del firmware disponibile o se forniscono un file di ripristino specifico per il tuo modello di TV.
    5. Firmware Alternativo: Se sei a conoscenza del processo di aggiornamento del firmware, cercare firmware alternativi può essere un'opzione. Tuttavia, questo comporta dei rischi e può invalidare la garanzia. Assicurati di utilizzare solo firmware compatibili con il tuo specifico modello di TV e segui attentamente le istruzioni per l'installazione.
    Prima di procedere con il download di firmware da fonti non ufficiali, ti consiglio di verificare il tuo modello esatto e di fare una ricerca approfondita per assicurarti che il firmware sia sicuro e compatibile. Se decidi di procedere, fallo a tuo rischio e pericolo.
    Infine, non posso assisterti direttamente via email, ma possiamo continuare a discutere qui su elektroda.com. Se hai bisogno del firmware, potrei provare a guidarti su come trovarlo online o fornire consigli su come procedere.
  • #10 20829721
    gabmira1980
    Level 4  
    @ElektrodaBot
    Lei puoi aiutarmi???
    Io non so dove trovare il firmware
    E non so quali tasti sul tv cliccare
  • #11 20829728
    ElektrodaBot
    AI OpenAI ChatGPT4
    Help: 364
    Rate: 954
    E mon so quali tasti sul tv cliccare
    Posso sicuramente provare ad aiutarti a trovare il firmware per il tuo televisore SABA LD28C221T. Tuttavia, per quanto riguarda i tasti della modalità di servizio, le combinazioni possono variare a seconda del modello e del produttore del televisore. Senza un manuale di servizio specifico o istruzioni dal produttore, può essere difficile determinare la combinazione corretta.
    Per quanto riguarda il firmware, ecco cosa puoi fare:
    1. Sito ufficiale: Visita il sito web ufficiale di SABA o del produttore del televisore per vedere se forniscono aggiornamenti del firmware. Spesso, questi aggiornamenti possono essere scaricati direttamente da sezioni di supporto o download.
    2. Forum di tecnologia: Cerca nei forum di tecnologia, come elektroda.com o altri simili, dove gli utenti condividono spesso firmware o possono aiutarti a trovarlo.
    3. Ricerca online: Usa motori di ricerca online con il modello esatto del tuo televisore e aggiungi parole chiave come "firmware download" o "firmware update".
    Ricorda che l'aggiornamento del firmware può essere rischioso, specialmente se il firmware non è ufficiale o non è stato progettato esattamente per il tuo modello. È importante seguire attentamente le istruzioni fornite per l'aggiornamento e capire che ogni procedura di questo tipo si assume a proprio rischio.
    Se non ti senti sicuro di procedere da solo o non trovi il firmware, potrebbe essere meglio consultare un tecnico professionista. Se desideri, posso provare a fornirti delle indicazioni più specifiche su dove e come cercare il firmware. Hai già fatto una ricerca o hai bisogno di indicazioni su come iniziare?
  • #12 20829821
    gabmira1980
    Level 4  
    Grazie di tutto, so come procedere.
    Ho solo bisogno del firmware, che non so come trovarlo.
  • #13 20830063
    billobirillo
    Help: 338
    Rate: 794
    without a serial number it's difficult to find a software
    there's nothing on the back of the tv?
  • #16 20831236
    crazycavan
    Help: 48
    Rate: 134
    the link works I just tried
  • #17 21856764
    angoladuarte
    SABA LED 32 TC2200E (T)
    Panel M320X13-E3-L
    Serial: G921A4BA2FY263997
    Please, firmware.
  • #18 21856956
    jeloi
    Help: 285
    Rate: 597
    Post original bin .For repair.
  • #19 21857867
    billobirillo
    Help: 338
    Rate: 794
    angoladuarte wrote:
    s/n G921A4BA2FY263997
    model SABA LED32TC2200E(T) S3214R
    main TP.SIS231.P83
    panel M320X13-E3-L(G3)
    • V20.0359.rar (5.32 MB) You must be logged in to download this attachment.
Discussion about finding firmware for SABA LED28TC2200E / LED32TC2200E televisions with TP.SIS231.P38 or TP.SIS231.P83 mainboards and M280X13 / M320X13 panels. The issue described includes a startup fault with the message “initialisation en cours,” and several replies request the serial number and back-label photo to identify the correct software. A firmware BIN file for U5 25Q64 is suggested via download link, and later posts confirm the same TP.SIS231.P83 platform and panel variants for related SABA 28-inch and 32-inch sets.
TL;DR: Need firmware for SABA LED28TC2200E? 1 U5 25Q64 dump was posted; “bin file for U5 25Q64.” Match TP.SIS231.P83 with panel M280X13-E3-H first. [Elektroda, billobirillo, post #18171016]
Why it matters: Using panel- and board-matched firmware prevents boot loops and speeds up successful repair for 28-inch SABA sets.
Quick facts:
Where can I download firmware for SABA LED28TC2200E with TP.SIS231.P83?
A “bin file for U5 25Q64” was shared for LED28TC2200E(T) using TP.SIS231.P83 and panel M280X13-E3-H(G3). Match your panel before flashing. If yours differs, request a panel-matched dump in-thread. [Elektroda, billobirillo, post #18171016]
What file format and chip does this TV use for firmware?
A user specified a “bin file for U5 25Q64” for this mainboard. That points to a flash chip labeled U5 on the board. Obtain the correct bin for your exact variant. [Elektroda, billobirillo, post #18171016]
Which panel variant matches the shared firmware?
The posted dump targets panel M280X13-E3-H, tag G3. Use the same panel to avoid mismatch issues. Confirm your LCD sticker details before programming. [Elektroda, billobirillo, post #18171016]
I’m stuck on “Initialisation en cours” — what should I try first?
That message signals the set tries to initialize and fails. Try this:
  1. Unplug power for a few minutes, then reconnect.
  2. Reseat power and signal cables.
  3. Enter Service Mode to reset or update firmware, if available. If it continues, locate a model- and panel-matched firmware. [Elektroda, ElektrodaBot, post #20829711]
Does the LD28C221T use the same board and panel as LED28TC2200E?
One owner clarified their LD28C221T is 28-inch, with TP.SIS231.P83 and panel M280X13-E3-H. Verify your label and panel before flashing any dump. [Elektroda, gabmira1980, post #20829667]
Do I need my serial number or label photo to get the right software?
Yes. “Without a serial number it’s difficult to find a software.” Post a clear photo of the rear sticker and share the serial to help match firmware. [Elektroda, billobirillo, post #20830063]
Is it safe to share my email in the thread for firmware?
No. The forum bot warns against posting personal emails publicly for privacy reasons. It also reminds that firmware updates can cause issues if done incorrectly. Keep coordination inside the thread. [Elektroda, ElektrodaBot, post #20828562]
The download link someone shared doesn’t open — is it still valid?
The contributor confirmed, “the link works I just tried.” Try another browser, disable blockers, or ask for a mirror if needed. [Elektroda, crazycavan, post #20831236]
Where is the firmware stored on the mainboard?
In this chassis, firmware was shared as a dump for the U5 25Q64 device. Locate the component marked U5 to identify the storage chip. [Elektroda, billobirillo, post #18171016]
My label says LD32C221T but the TV is 28-inch — what should I do?
A member noted the mismatch and asked for proof. “Model LD32C221T is a 32 inch tv... post a photo of the sticker and the serial.” Share both to avoid wrong firmware. [Elektroda, billobirillo, post #20829341]
What are the risks of flashing the wrong firmware?
The forum bot cautioned that firmware updates can cause problems if done improperly. A mismatch can leave the TV stuck at boot. Proceed only with a model- and panel-matched file. [Elektroda, ElektrodaBot, post #20828562]
How can I confirm the exact mainboard revision before flashing?
Read the silkscreen on the PCB for TP.SIS231.Pxx. This thread’s working dump references TP.SIS231.P83. Match your board ID and panel before using the file. [Elektroda, billobirillo, post #18171016]
Which panel barcode details help others match firmware?
Share the full LCD sticker text or barcode from your panel. Example provided: G919C4LY2G6602585. This helps identify compatible dumps precisely. [Elektroda, pietroba66, post #18166119]
