DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings
Bałdyzer 17268 10
How do I stop the DEFRO Eko Duo Uni 25 kW boiler’s hearth base from sliding out, and what settings will reduce its coal consumption?
The thread’s practical advice is to give the boiler more air and less fuel: increase the fan air supply, clean the air ducts in or under the retort, and reduce coal feed time or increase the feeding pause; if needed, also reduce the amount of fuel in each portion and feed it more often [#18390890][#16844988] If the fire is smoky or unburned, the boiler is acting too much like a gasifier, so it needs enough oxygen and temperature; one user suggests minimizing carbon feed, increasing fan settings, and optionally shrinking the firebox with chamotte bricks [#18391169][#18391322] For wood on the emergency grate, the replies say it will not burn cleanly in parallel with automatic coal firing and is only for emergency heating with the fan off and the ash-pan door properly open [#18390890] Another reply asks whether the exchanger is clean, since that also affects fuel use [#18391257] Typical reported consumption in similar houses was about 18–20 kg of coal per day for around 200 m², so 35–40 kg/day looks high and points to tuning or airflow issues [#18391718][#18391257]
  • Hearth base shifting and excessive coal consumption
    #1 16169406
    Bałdyzer
    Rate: 227
    I have two problems with the DEFRO Eko Duo Uni 25KW boiler. I would add ,. that the boiler is new, installed by a specialized company in September 2015.
    First of all, in the photo below I marked it with a yellow arrow, it is such a thick iron base of the hearth, after it the burnt ash moves into the drawer. From time to time she moves left and falls down. Does it have any blockage so that it doesn't move? Do you have to put out the firebox, choose ash to mount it correctly?
    The second problem is the optimal settings for this furnace. I have the impression that the stove burns a lot of fuel for heating a 7-year-old well-insulated house with new windows. Around 35-40 kg of eco-pea coal is burned daily, with relatively light winter, which gives at least 6-7 tons for the heating season. In the previous furnace, Ogniwo 28KW for the season had 4 tons of fleet and 2-3 meters of wood for kindling. Maybe some of you have experience and by trial and error came to more economical settings of this furnace. I currently have factory settings, I haven't changed anything since the day the furnace was installed.
    DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings
  • #2 16179591
    Bałdyzer
    Rate: 227
    I have terribly unburned coal in the ashtray, no one has this furnace to enter your settings?
    DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings DEFRO Eko Duo Uni 25KW - The furnace base slides out for optimal settings
  • #3 16844988
    zamelek
    buddy, reduce the feeding time or increase the feeding pause by 100% on a good morning
  • Wood on upper grate smokes without separate ignition
    #4 18390086
    Bałdyzer
    Rate: 227
    I have such a question, in this boiler with Defro feeder can you smoke in parallel on the second grate with wood? The point is that the boiler normally works automatically on eco-pea coal and during this time I give a few blocks of dry beech to the upper grate to reach the temperature faster and burn less coal.
    Today, when I gave a few blocks of wood, after a few minutes I opened the upper door and instead of fire there were large clouds of thick smoke, and the chimney was very dusty.
    I will only add that I did not light this wood separately, counting that it will light from the pea coal that burns below this grate and this wood smokes more when it burns.
  • Increase air supply and reduce fuel feed
    #5 18390890
    Sstalone
    Help: 72
    Rate: 398
    Bałdyzer wrote:
    I will only add that I did not light this wood separately, counting that it will light from the pea coal that burns below this grate, and this wood smokes more when it burns
    You need to have knowledge to experiment. How can you burn wood additionally, if you do not burn coal? You just don't have enough air in the hearth. Increase the air supply by the fan, and you may need to clean the air supply ducts in or under the retort. This is the first thing you should do. If you get the complete burning of peas, and you have too much heat at home, then you will have to reduce the feeding times and intervals and reduce the amount of air fed accordingly. The amount of air is regulated by the fan speed and the size of the gap in the fan. Pictures suggest that you also give too much fuel. If you can, try giving smaller portions and more often.
    As for burning wood on a water grate, you will never get clean burning, it is used for emergency heating as there is no electricity, and not to reduce heating costs. You burn wood with the fan off and coal feeding, with the ash pan door open properly.
  • Wood on a water grate burns dirty by design
    #6 18391129
    Bałdyzer
    Rate: 227
    I understand that this wood cannot be burned cleanly with eco-pea coal, but it is white smoke from very dry (seasoned from 10 years) beech wood so it is not so harmful. After all, somehow this wood burns slowly and raises the temperature, which makes the feeder less eco-pea coal. I still have about 10 meters of wood left so on cold days when I give 3-4 blocks on the upper grate, I think nothing will happen. The neighbors in the countryside have old cinderella, smoke grandpa and poison the area 10 times more than I do.
  • Reducing fuel feed and increasing fan to cut smoke
    #7 18391169
    Waski85
    Rate: 22
    I hope you have a house with 300m2 because I have a 100 summer house with an area of 120m2, medium insulated (the walls of the ground floor are not insulated because they are stone) and a 12 kW stove.
    A lot of smoke in the hearth means that your furnace works as a wood gas generator. All you need now is oxygen and temperature. You will provide everything by minimizing the carbon feed and increasing the fan settings as much as possible. You can also try to reduce the hearth by placing chamotte bricks on the grate.
  • Increase fan and reduce fuel feed for gasification
    #8 18391247
    Bałdyzer
    Rate: 227
    I have a house about 200 meters but it is a relatively young 12 year old house, well insulated, wooden windows in good condition. I will try to increase the blow force and reduce the carbon dose, with the current January warming the furnace should be able to do it.
    And what do you think about this idea. How about a little spruce wood in the middle of an emergency grate, and 3-4 thick hard wood blocks next to it? Small wood should be easily ignited and thick wood blocks will ignite.
  • #9 18391257
    Sstalone
    Help: 72
    Rate: 398
    @ Bałdyzer and the exchanger clean? I need at 18 degrees outside 18 kg of coal per 200 m2 at 21 degrees indoors, 10 cm thick EPS boards on the walls.
    What temperature do you keep indoors?
  • Oversized firebox may be cooling wood gases
    #10 18391322
    Waski85
    Rate: 22
    You probably have too big a stove, not too small. The chamber in which you want to burn wood may be too large and the gases formed from gasification of wood, they cool down too much and cannot ignite.
    Wood burns best in a layer of about 20 cm and of course small brushes will burn better than large pieces. On trial, fill the chamber tightly, wall-to-wall with small brushes.
    Check your house's needs on the website www.lowłow flatwie.pl and enter the result.
    If you can, put a photo of the flame in the burner during normal operation. I'm sorry they are here.
  • Indoor temperature and coal use in mild winter
    #11 18391718
    Bałdyzer
    Rate: 227
    I keep around 21-22 degrees indoors. Daily combustion with such a light winter as today is on average about 20kg / day with hot water for 4 people. I live in the mountains so here in winter it is usually around 4-5 degrees less than in Żywiec and further north.
The discussion revolves around issues faced with the DEFRO Eko Duo Uni 25KW boiler, specifically regarding the movement of the iron base of the hearth and the boiler's fuel efficiency. Users report problems with unburned coal in the ashtray and suggest adjustments to feeding times and air supply to improve combustion. There are inquiries about burning wood alongside eco-pea coal, with advice given on managing air supply and fuel portions to achieve cleaner burning. Participants share their experiences with heating needs, fuel consumption, and optimal settings for better efficiency in well-insulated homes.
