Optimizing Furnace Settings for Ekogroszek Piece Witkowski: 25 KW Boiler, Timel SKZP-02 Controller
gangsta529 12042 10
How can I tune a 25 kW ekogroszek boiler with a Timel SKZP-02 controller to reduce coal consumption and keep high thermal efficiency in an old heating system without a 3/4-way valve?
To reduce coal use, the boiler and return temperatures need to be kept stable, and several replies say that a 3/4-way (4D) valve is the proper solution in an old installation [#16728754][#16744021][#16744077] One user with a similar setup recommends keeping the room thermostat at one constant temperature, e.g. 22°C, with 1°C hysteresis, opening the chimney draft about halfway, adding a draft regulator under the blower, and using interval work around 60 s pause / 10 s feed in frost or 90 s pause / 15 s feed [#16824581] That same setup used a boiler temperature of 42°C with about 240 l of water and reduced water flow, which gave about 16–18 kg of coal per day [#16824581] Another reply says that in fuzzy logic / power modulation, the minimum boiler power is often too low in spring and autumn, so try increasing it to around 30% instead of 5% [#16829404] A general warning from the thread is that settings that look economical can backfire if they cool the boiler too much, because the boiler then burns extra fuel just to warm itself back up [#16744077]
  • #1 16728616
    gangsta529
    Hello, I bought a stove in Witkowski in the summer (I applaud for the quick delivery of the order with delivery to my home, as well as the quality of the product). I have a problem with the furnace settings for low combustion, and the highest thermal efficiency. I have a 25 KW boiler heating a house with an area 220 meters, 140 liters water reservoir. Burning for today's daily I have a level of 35 kg. The furnace controller is Timel SKZP-02 to which I have plugged room module to read the temperature, the exhaust sensor and the weather module.
    Furnace settings:
    Pre-set temperature 55 *
    Hot water 50 *
    Reg. Peaceful T.comfortowa 22 *
    T.economical 20 *
    Hysteresis 0.2 *
    Room Regulator
    weather correction 0
    switch-off temperature every 20 *
    Torch
    - Automatic Work Mode
    Modulation
    Min. Boiler power% 5
    Maximum boiler power% 100
    Maximum time of exceeding the temperature 60
    Air
    - air min (10% of the burner power) 5
    - max air (100% of the burner power) 25
    - blow when giving fuel% 15
    Fuel
    - calorific value kWh / kg 7.8
    - fuel dose correction (-30% / + 30%) -10%
    - calorific value in MJ / kg 28.1
    Interval Work
    - 5s administration time
    - break time 80s
    - air 25%
    -Histheresis 5 *
    Vigil
    - break 10min
    - blowing time 15s
    - air 20%
    Extinguishing time 120 min
    potential of the feeder (kg / h) 15
    time of feeding in the machine 6s
    max. exhaust temperature 220 *
    rated power 25
    I do not have a three-way / four-way valve because it's an old installation, mixer etc. the flap from the chimney is closed to 30%
  • #2 16728651
    mietek654
    Help: 140
    Rate: 292
    Hello, what are the valves on the radiators?
  • #3 16728660
    gangsta529
    I have thermostatic valves at panel radiators, but in the installation, I also have cast iron radiators that work with "full power".
  • #4 16728754
    mietek654
    Help: 140
    Rate: 292
    Valves must be everywhere and necessarily a 3 or 4 way valve. Only then can you play with the settings.
  • #5 16729179
    gangsta529
    It seems to me that there are ways to change the furnace settings to reduce the combustion of eco-pea coal without a 3/4-way valve, unless I am wrong to please correct my statement.
  • #6 16730000
    mietek654
    Help: 140
    Rate: 292
    If you think so, then look further. greetings
  • 4d valve and reduced pump flow improved temperatures
    #7 16744021
    Borek_PL
    I also have an old installation, but the 4d valve I installed mainly for the possibility of independently regulating the temperature of hot water and heating - I consider it a very good decision.
    I do not keep accurate statistics, but I have the impression that I was significantly affected by the reduction of water flow through the pump which - (I now have about 1.2 m ^ 3 / h) increased the difference in supply and return temperatures (around 55/48) because earlier they were almost similar.
    Each building and installation is different, no one will give a recipe, it is worth considering how much the previous system pulled you in such weather conditions, but 35kg a day when it is outside +10 oC can actually raise concerns.
    (I also have the boiler temperature 55, hot water 50, but the house is smaller, the controller is in automatic mode with power modulation (works in the 3-8kW range), I also left 2 old radiators without thermo heads and I can not wait for it now, when my imprudent I will fix the decision)
  • #8 16744071
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    Well, sympathize as at the end of September. 35kg x30 days = 1050kgx 850 PLN / T = 940 PLN / month Seperation / October. I pay so much for 2 months: November-December for gas with dubious subscription, transfers, etc.
  • Boiler settings can cut fuel use without a valve
    #9 16744077
    bearq
    Help: 414
    Rate: 1612
    Everything is set under conditions and a given fuel batch. You have to change the settings in such a way as to maintain the maximum temperature stability of the boiler, often the seemingly economical setting is incorrect because it leads to cooling the boiler and increasing the combustion which instead of heating the house already warms up the cooled boiler.
    There is a nice side somewhere which roughly calculated the amount of fuel in kg on the basis of data on the building, insulation, boiler, etc. For me it worked quite well.
  • #10 16824581
    AZUKS
    Rate: 311
    My advice is the following I had a similar installation.
    Room thermostat - one temperature for the whole day, eg 22 * C, hysteresis 1 * C (lowering the night by 2 * C causes that the stove will save in the day, I will use it twice in order to obtain a higher temperature)
    Adjusting the chimney draft - open in half, or quite, and buy a chimney draft regulator with a flap under the blower, then it will automatically close the string.
    Interval work - with me I had a feeding ratio of 1-6, in frosts 1-5, that is 60s waiting and 10s feeding, you can set 90s downtime and 15 s feeding - a lot faster bake temperature and do not sinter, and hysteresis reduced on 1.5 * C
    I am still due to the fact that I had a tube from the power supply 40 I screwed the valve on the supply reducing the water flow to 1/3 of the diameter, and the pump was always on 1, (3 ranges available), I set the boiler at 42 * C because I have 240l and the water is hot and the water pump very rarely turns on. With this setting, I used about 16-18 kg per day.
  • #11 16829404
    Borek_PL
    In the manual of my driver with power modulation it is written that this mode "fuzzy logic" in the period with low heat consumption spring / autumn is not very economical and it is recommended to set the minimum power parameter to a higher value, so try to raise it, eg 30% .
    I have the impression that it also confirms to me.
The discussion revolves around optimizing the settings of a 25 KW Ekogroszek boiler with a Timel SKZP-02 controller for efficient low combustion and thermal performance. The user reports a daily fuel consumption of 35 kg for heating a 220 m² house with a 140-liter water reservoir. Participants suggest various adjustments, including the use of thermostatic valves, the importance of maintaining boiler temperature stability, and the potential benefits of a 3 or 4-way valve for better control. Recommendations include setting a room thermostat to a consistent temperature, adjusting chimney draft, and modifying feeding intervals to enhance efficiency. The conversation highlights the need for tailored settings based on individual installation conditions and fuel characteristics.
