VW Golf V (2008) 1.6 8V: Mounting Rear View Camera on Non-Factory Radio - Connection Guide
dareczek3000 11973 6
  • #1 16172992
    dareczek3000
    Rate: 28
    Hello everyone. I want to mount a reversing cam in VW golf 5 1.6 8V 2008 for a non-factory radio. Currently, I connected everything according to the instructions, i.e. under the rear lights. Everything works until I start the engine - then the image is lost. I made an additional power source - then the camera works, but that's not the point. Apparently, it connects to the relay only that I do not have it. There is a control module. Does anyone know how to connect it?
  • #2 16173010
    ladamaniac
    Help: 724
    Rate: 2079
    Plus under the backlight bulb, minus the weight and must walk. You probably connected the mass incorrectly.
  • #3 16173063
    dareczek3000
    Rate: 28
    Red or plus I have a light bulb from reverse black to ground and in addition one cable from the radio is also to be connected to the reverse light.
  • #4 16173676
    Pawel wawa
    Help: 1262
    Rate: 4433
    You need to give an additional relay for the rear lights, power from the relay only for your radio and cam.
  • #5 16175013
    dareczek3000
    Rate: 28
    I am a bit weak in electricity, can you ask for a more detailed description of what the relay should be and how to connect it?
    andrzej20001
    Help: 1578
    Rate: 6675
    Regular transfer for PLN 5
    30-battery power supply via a 10A fuse from the box
    87-out webcam
    85 mass
    86-reversing light
  • #7 16177997
    dareczek3000
    Rate: 28
    Works thanks to the relay. Thank you very much for your help
The discussion revolves around mounting a rear view camera on a 2008 VW Golf V 1.6 8V with a non-factory radio. The user initially connected the camera under the rear lights, but the image was lost when the engine started. Suggestions included ensuring proper grounding and connecting the camera to a relay for stable power. A detailed relay connection was provided, specifying battery power, webcam output, ground, and reversing light connections. The user confirmed successful operation after implementing the relay solution.
