Electric Boiler Leak: Repair or Replace? - Bathroom Flood, Causes & Solutions
jodalkr 33159 8
  • #1 16180507
    jodalkr
    Welcome.
    In the morning I noticed a flood in the bathroom, the reason for the boiler. I'm inserting a movie. Is the boiler ready for repair or should I give it peace? How do you think? What to do?
    Thank you in advance for every answer.
  • #2 16180529
    k124l
    Help: 31
    Rate: 125
    The first thing is to disconnect it from the power supply and the leak can be seen as if from the area of this indicator you could try to tighten it.
  • #3 16180532
    stanislaw1954
    Help: 2013
    Rate: 4673
    Turn off the cold water supply, remove the plug from the socket. Loosen the bottom cover and try to locate the cause of the leak.
  • #4 16180537
    jodalkr
    Naturally, I disconnected right away. Underneath the power control knob is also wet and as if everywhere in the middle, but I have no idea, you can not see where this water is flying from ...
  • #5 16180545
    MACIEK_M
    Help: 111
    Rate: 462
    Since there are no fairies here, first disconnect from the network, remove the cover and see where it is leaking, later we will "advise" you :D .
  • #6 16180556
    jodalkr
    The point is that calling earlier to one "professional" he for half a minute of the phone conversation was able to state that since it is leaking is a hole and a rubbish boiler and you need a new one. And I would prefer to try it with it ;)
  • #7 16180561
    stanislaw1954
    Help: 2013
    Rate: 4673
    I did not look at the video, but this thermometer is not screwed, so you will not improve anything, and the leak is not always in the hole, only there is a hole in the foam insulating the tank, so it's easier to get out of the water.
  • #8 16180607
    arturdip
    Help: 170
    Rate: 324
    Unfortunately, leakage can be anywhere in the tank (usually on welding). Scraping foam and finding a leak is a lot of work and the effect is very doubtful. I would rather look for a new one. I have already mentioned it twice. Mostly after 6 years it rains ( one year after the guarantee) item art
  • #9 16180623
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    If it rusted from the top, it has a sieve inside.
The discussion revolves around a user experiencing a leak from an electric boiler, resulting in a bathroom flood. Initial advice includes disconnecting the power supply and cold water, then inspecting the unit for the source of the leak. The user expresses frustration after a previous professional suggested immediate replacement without thorough inspection. Responses highlight that leaks can occur from various points, often at welds or through insulation, and repairing may be labor-intensive with uncertain results. Many contributors recommend considering a new boiler, especially if the unit is older than six years, as leaks are common after this period.
