3mk HardGlass on Samsung Galaxy S5: Slight Image Distortion and Refraction - Application Issue?
Jachuw90 8349 5
  • Possible inherent image distortion from 3mk HardGlass
    #1 16196080
    Jachuw90
    Rate: 39
    I bought yesterday a tempered glass for Samsung Galaxy S5 from 3mk, type HardGlass. Sticking the glass went according to the instructions. I glued them perfectly to the phone screen, but after turning on the phone, I have the impression that the glass slightly distorts the displayed image. I can compare it to a slight but even grease on the entire display, which makes the light coming from the display a bit refracted. Hope you know what I mean. This effect can be seen when we touch the screen with a greasy finger and at this point the image will seem to shimmer. Before sticking the foil, I degreased the entire front panel with my isopropyl alcohol (just to make sure it was clean), then with a damp 3mk cloth, and also polished it dry so that there were no ferns or streaks.
    I did something wrong, does this type just have it?
  • #2 16196160
  • #3 16197489
    Jachuw90
    Rate: 39
    It will be best to see what I mean in the film and photos.
    Pictures
  • #4 16197678
  • #5 16197700
    Jachuw90
    Rate: 39
    It wasn't about that. It's hard to capture, but it's clearly visible in the video. Maybe I will introduce the frame:
    it looks a bit like pixels
  • #6 16197738
