[Solved] Samsung Galaxy S6 Edge - Vertical green line / strip on Amoled displays
pawelhd2003 5487 2
  • Excess ribbon curvature may cause green line damage
    #1 16652499
    pawelhd2003
    Rate: 23
    when regenerating the Amoled display, sometimes a green vertical line appears at the end of the process along the entire length of the Amoled display.
    I think it is a matter of too much curvature towards the other side of the ribbon from the display, however, it has to be bent to put the display on the mat during lamination.
    Does anyone have experience with such a problem? When does the damage occur and can it be repaired or avoided?
  • #2 16654062
    tonk
    GSM specialist
    Help: 137
    Rate: 57
    hello, unfortunately you can not fix it, but when it breaks, it is difficult to predict without seeing your repair process (sometimes in edgas it would also be difficult) in my opinion you should check the display after each stage, i.e. gluing, sepaling the glass, cleaning, etc.
  • #3 18369327
    pawelhd2003
    Rate: 23
    You have to do each action carefully, then there is less damage
