KARCHER K 5 1.180-633.0 - Low pressure, vibration of the washer and hose
Śniący 11937 4
  • #1 16207542
    Śniący
    Level 19  
    Help: 6
    Rate: 51
    Hello, there is a problem in the form of low water pressure, the stream of water seems to be intermittent (very fast pulsation), the hose vibrates significantly, it is trembling all over, you can also feel vibrations on the lance. While I set the pressure to low, you can clearly see that the water is not flying smoothly, as if air is being supplied instead of water, after disconnecting the hose and lance from the washer and turning it on, it still behaves like a vibrator.
    As it is already after the warranty (30 months from the purchase), I took apart a bit and apart from water mixed with grease, I found nothing with oil, where to look for the cause?
    • KARCHER K 5 1.180-633.0 - Low pressure, vibration of the washer and hose k4.jpg (1.73 MB) You must be logged in to download this attachment.
    • KARCHER K 5 1.180-633.0 - Low pressure, vibration of the washer and hose k1.jpg (2.6 MB) You must be logged in to download this attachment.
    • KARCHER K 5 1.180-633.0 - Low pressure, vibration of the washer and hose k2.jpg (1.66 MB) You must be logged in to download this attachment.
    • KARCHER K 5 1.180-633.0 - Low pressure, vibration of the washer and hose k3.jpg (1.12 MB) You must be logged in to download this attachment.
  • #2 17877942
    Tomek79
    Rate: 35
    Buddy, did you manage to do something about it? Because I have very similar symptoms. Hose vibration and low pressure. I took the washcloth apart ... and nothing looks suspicious.
  • #3 17935505
    Śniący
    Level 19  
    Help: 6
    Rate: 51
    One of the valves was loose, it was disengaging, I really glued the super glue, washed the center with new oil, and so far it works.
    If the situation repeats, I will replace all valves with new ones.
  • #4 19771228
    Śniący
    Level 19  
    Help: 6
    Rate: 51
    The problem occurs about every year, it helps to take the pump apart, clean it, pour new oil. I have not replaced the valves.
  • #5 21602937
    lewand621
    Hello, similar action: intermittent pulsing, hose vibration, brief on and off, and the cause was the gun, not the lances, in which I replaced the orings and so far it works. Greetings.
