Karcher K5 Washer: Low Pressure Issue when Releasing Lance
hanys_z_ch 22374 6
  • #1 16871745
    hanys_z_ch
    The Karcher K5 washer does not turn on at full pressure, only when I release pressure on the lance. What could be the reason?
  • #2 16881144
    prezesss89
    Rate: 15
    I had a washer k5.55 it was normal for me but after stopping work and switching it on again (using the button in the lance) it gave low pressure, it was necessary to disconnect the lance to pour out water from it and only then gave normal pressure, I undressed it all and the center of the valve was sealed such as wax, I think that it was cleaning the washer after washing the unwashed chemistry and I washed it all and works, now when I wash something with chemistry, after the procedure I put the hose from the chemistry tank into the water bottle and turn it on for a moment rinsed well and polka what works for now
  • #4 18794581
    Yoorek1
    I don't know for how long, but my advice was:
    1. Connect the water hose
    2. Detach the lance from the pressure hose - there is a yellow button on the lance for this (i.e. the pressure hose is connected to the washer)
    3. Turn off the water
    4. Wait 5 minutes (water is to drain normally from the pressure hose during this time)
    5. Turn off the water
    6. Connect the lance
    7. Turn off the water
    8. Turn on the washer
    It should work
    pozdr
    Y
  • #5 20007434
    Federal1
    Rate: 9
    Hanys, what was with this washer because I have the same problem. I started everything up and it still does not run at high pressure.
  • #6 20856090
    kozik150184
    Has anyone solved this problem?
  • #7 20991337
    naprawnarzedzie
    Help: 11
    Rate: 58
    firstly, check whether the washer turns on without the lance, on the gun itself, and after releasing the trigger it turns off the engine normally, this is important information for further diagnosis
✨ The Karcher K5 washer is experiencing low pressure issues when the lance is released. Users suggest several troubleshooting steps, including checking the valve for blockages, ensuring proper water connection, and testing the washer without the lance attached. One user reported that cleaning the valve resolved their issue, while another provided a detailed procedure for reconnecting the lance and draining the pressure hose. The discussion highlights the importance of diagnosing the washer's operation with and without the lance to identify the root cause of the low pressure.
