Astra G 2.0 DTI - Locating Thermostat in Opel Astra G 2.0DTI 101HP (2001 Model)
ziooober88 10200 7
  • #1 16207901
    ziooober88
    Rate: 491
    Hello, I have Opel Astra G 2.0DTI 101HP from 2001 Could someone tell me where the thermostat is in this car?
  • #2 16207919
    Daro122
    Help: 165
    Rate: 751
    Next to the oil dipstick, a visible water hose is inserted into the thermostat tip.
  • #3 16207920
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
  • #4 16208230
    ziooober88
    Rate: 491
    Is it better to replace the whole or just the contribution is enough?
  • #5 16208238
    zubereq
    Help: 13
    Rate: 89
    From experience I will say that it is better all with the housing, with cartridges, it is different.
  • #6 16208390
    ociz
    Help: 1379
    Rate: 3486
    Only the whole. The insert itself can be risked if it is from the same manufacturer as the housing.
  • #7 16208628
    ziooober88
    Rate: 491
    And which company to buy this thermostat?
  • #8 16237792
    ziooober88
    Rate: 491
    Hello, thermostat replaced. I bought the entire WAHLER set - 120 PLN. Best regards.
The thermostat in the Opel Astra G 2.0 DTI (2001 model) is located next to the oil dipstick, where a visible water hose connects to the thermostat tip. It is recommended to replace the entire thermostat assembly, including the housing, rather than just the insert, to avoid compatibility issues. A user reported purchasing a complete WAHLER thermostat set for 120 PLN.
