Replacement of the gasket under the head - What is the cost of replacing the gas
Michalw1992 53187 12
How much should it cost to replace the head gasket on a 2000 Opel Astra 1.7 DTI, including the necessary related work and parts?
A realistic estimate is about PLN 1,000 ±200 when replacing the gasket together with all seals and a complete timing kit, although prices vary by region and workshop. [#16894894] Labor alone may cost around PLN 500. [#16892575] The work can also require head planning, new head bolts, manifold and valve-cover gaskets, valve and guide inspection, valve-stem seals, oil, filters, and coolant. [#16893105] With this broader scope and possible additional engine work, the total may reach approximately PLN 2,000. [#16893105]
  • #1 16892554
    Michalw1992
    I have a problem, I recently bought a car Opel Astra 1.7 DTI from 2000. This is the Astra 2 hatchback Comfort 5-door series.
    The problem is that it smells a lot of cold and takes a lot of coolant for 95% damaged gasket under the head, I'm going to fix it after Christmas only I do not have the slightest idea how much it can cost, maybe some of you already exchanged the gasket in this model I he knows how much it costs.
    I would like to thank you for all the helpful comments and greetings.
  • #2 16892575
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. If it is not cracked, planning, gasket for heads, labor is so 500 PLN And we do not know yet how with timing or not for replacement is an additional cost.
  • #3 16892898
    ^ToM^
    Help: 495
    Rate: 2939
    You ask about the cost of replacing the gasket itself. In this case, the replacement should not cost more than PLN 200-300.
  • #4 16892997
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    ^ToM^ wrote:
    the exchange should not cost more than PLN 200-300.
    It's a joke?
  • #5 16893105
    diablo23248
    Help: 102
    Rate: 614
    Where are the cheap mechanics?
    The labor itself is about PLN 500
    Head gasket, gaskets for manifolds and valve cover, planning, new head bolts, valve timing, valve and guide check, valve sealants, for a large mileage for one job, I would change rings on the pistons and check the acetules. New oil and filters + radiator fluid. Lightly counting about PLN 2,000.
    If I'm wrong, correct me ...
  • #6 16893258
    Cobrat
    Help: 35
    Rate: 502
    T5 wrote:
    It's a joke?
    There are many who will do enough ... The second issue is that some people do it after hours ;)
  • #7 16894745
    Meteo33
    Help: 12
    Rate: 84
    A lot depends on the region. In the largest cities, service prices are often twice as high as in small towns.
  • #8 16894894
    szymitsu21
    Help: 343
    Rate: 1300
    For me, 1000 PLN plus minus 200.
    And in addition all seals and timing KPL. With such a job, I can give a guarantee.
  • #9 16895072
    zibi999
    Help: 10
    Rate: 60
    It's best to look at the web addresses and to call up a drive to talk prices are varied
  • #10 16895090
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    Just like the quality of this service.
  • #11 16895164
    zibi999
    Help: 10
    Rate: 60
    Exactly, but there are also good workshops that provide really excellent quality of services.
  • #12 16895245
    bandi21
    Level 30  
    Help: 126
    Rate: 655
    probably that there are good workshops but not for PLN 200
  • #13 16895270
    zibi999
    Help: 10
    Rate: 60
    Okay, we're not gonna mess the forum with receipts I think; p
    The amount is not the most appropriate as to the quality.
The discussion revolves around the cost of replacing the head gasket in an Opel Astra 1.7 DTI from 2000. Users provide varying estimates for the replacement, with costs ranging from PLN 200-300 for the gasket alone to PLN 1,000-2,000 for a comprehensive service that includes labor, additional gaskets, head planning, and other necessary checks and replacements. The cost can vary significantly based on the region, with larger cities typically charging higher rates. Participants emphasize the importance of quality service and suggest researching local mechanics for accurate pricing.
TL;DR: For an Opel Astra G 1.7 DTI, expect PLN 500–2,000; “The labor itself is about PLN 500.” [Elektroda, diablo23248, post #16893105] Why it matters: Knowing real-world ranges helps you budget, compare quotes, and avoid low-quality shortcuts. This FAQ is for first-time owners asking how much a head-gasket job should cost and what’s included.
How much does head-gasket replacement cost on an Astra 1.7 DTI?
Typical budgets range from PLN 500 for labor-only to about PLN 2,000 for a comprehensive job. The higher figure includes machining, new head bolts, manifold gaskets, timing work, fluids, and checks. Plan your scope first, then match quotes to the scope. [Elektroda, diablo23248, post #16893105]
What does a proper ‘full job’ include?
Expect head gasket, manifold and cover gaskets, head planing, new stretch bolts, timing set assessment or renewal, valve checks and seals, oil and filters, and fresh coolant. “Lightly counting about PLN 2,000” aligns with that scope. Ask shops to itemize each task. [Elektroda, diablo23248, post #16893105]
Why do quotes vary so much by location?
Regional labor rates and shop overheads drive differences. In large cities, prices often run about twice those in smaller towns. One poster summarized it plainly: “A lot depends on the region.” Factor travel costs if you choose a lower-cost area. [Elektroda, Meteo33, post #16894745]
Is a PLN 200–300 quote realistic?
Such quotes exist but usually cover a minimal scope and limited accountability. Some mechanics do side jobs “after hours,” which can reduce price but increase risk. Verify machining, bolt replacement, and warranty before accepting a low quote. [Elektroda, Cobrat, post #16893258]
Should I replace the timing set during the gasket job?
Timing may add cost if due. The head comes off anyway, so access is open. If the timing set is worn or near interval, replacing now prevents paying labor twice. Ask for a separate line item and parts list on the quote. [Elektroda, Pedros050, post #16892575]
What if the cylinder head is cracked or badly warped?
Cracks and excessive warping change everything. Planing alone won’t save a cracked head, and costs rise with repair or replacement. Shops often give a conditional quote: valid if the head is not cracked. Build a contingency into your budget. [Elektroda, Pedros050, post #16892575]
Which extra parts are smart to replace while you’re in there?
Beyond the gasket set and bolts, consider valve stem seals, timing components, fluids, and filters. On high-mileage engines, some shops suggest piston rings and related checks during the same teardown to avoid repeat labor. Confirm necessity before approving. [Elektroda, diablo23248, post #16893105]
How do I get a trustworthy price and avoid surprises?
Call multiple workshops and discuss scope in person. Prices vary, and speaking on-site improves accuracy and accountability. Ask each shop to confirm machining, bolt replacement, timing, fluids, and warranty in writing before booking. [Elektroda, zibi999, post #16895072]
Quick 3-step: how to request a head-gasket quote that’s apples-to-apples?
  1. Share symptoms and ask for a written scope (machining, bolts, timing, fluids).
  2. Request line-item pricing and warranty terms.
  3. Visit the shop to validate capability before scheduling. [Elektroda, zibi999, post #16895072]
Do reputable workshops offer a warranty on this repair?
Yes. Some mechanics explicitly state they provide a warranty when they replace all seals and the timing set as part of the job. Warranty often depends on using new bolts, proper machining, and fluids. Confirm coverage length and conditions. [Elektroda, szymitsu21, post #16894894]
Why does labor alone hover around PLN 500?
That figure reflects the teardown, reassembly, and coordination with head planing if needed. It assumes no major complications. If timing or additional parts are required, labor or total cost increases. Ask whether valve clearances and checks are included. [Elektroda, Pedros050, post #16892575]
Are big-city quotes really up to double?
Yes, posters report that service prices in the largest cities can be roughly twice those in small towns. If you can travel, compare quotes regionally. Balance savings against time and potential follow-up visits. [Elektroda, Meteo33, post #16894745]
What should I budget if I want everything refreshed at once?
Plan for about PLN 2,000 when you include machining, new bolts, seals, timing work, fluids, and valve checks. This consolidates labor and reduces repeat tear-down risk. It is a practical target for high-mileage engines. [Elektroda, diablo23248, post #16893105]
Does a higher price always mean better quality?
Not automatically. Price alone is not the best indicator of workmanship. Ask for scope, parts brands, machining details, and warranty. One poster noted the amount isn’t the most appropriate measure of quality. Vet the shop’s process instead. [Elektroda, zibi999, post #16895270]
Can someone do it cheaply ‘after hours’, and what’s the risk?
Yes, some mechanics take side jobs after hours, which can lower the price. Risks include limited documentation, unclear scope, and weaker guarantees. Cheap work often excludes machining, new bolts, or timing, raising failure risk later. [Elektroda, Cobrat, post #16893258]
