Seat Ibiza 6j Power Steering Failure - 00816, Steering Angle Sensor Error, 6R...156B Pump
kubus_111 17967 3
  • #1 16209126
    kubus_111
    Seat ibiza 1.2 tsi 2010
    Hello, the topic has already been raised but it is a bit different for me
    the car had a collision, the old pump was working but there was a pump error, the support died after 3 days. I bought a pump with the same numbers, in this case 6R ...... 156B. I assumed, but still no support. The pump reaches the current, there are no errors on ODIS, the VCDS displays error 00816, (steering angle sensor). There was no error on the old pump. I do not know where to look, or suggest that the pump is working (I bought a used one, but it went to the end)?
    I tried to adapt the vcds angle sensor but it doesn't give me access to basic settings after entering 40168 as the code.
    Please help
    ps.
    The pump does not react when the sensor is disconnected without changes
    Voltage 0 in VCDS or ODIS measuring blocks
  • #2 16209199
    dawidos145
    Rate: 19
    look at the power supply cables to the pump, either short circuit or break, in general the battery should also be full, the car after the accident may still be in emergency mode, remove all errors, the assistance should generally work (adapt) after a short drive
  • #3 16209270
    akamix21
    Rate: 70
    coding must be done
  • #4 16210142
    sk700
    Help: 173
    Rate: 420
    Rewrite the coding from the old pump, there the angle sensor is either on a mangle or shared with ESP under the steering wheel, I bet you have the wrong type selected.
