Audi A3 8P Central Locking Issue: Key Locks but Struggles to Open, Trunk Ticking, Indicator Lights
98mati11 7206 5
  • #1 16210049
    98mati11
    The problem is the following car locks with the key without problems but already with opening it there is a problem it just doesn't open. You can hear the ticking from around the trunk, the direction indicators light up but it will not close the car. What may be the problem? One more question, if you press the close button several times on the key, you can reprogram something that the reason is that the electric windows do not open?
  • #2 16210104
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    The central mate is ground controlled, but the managing or managing actuator is or is in the front door.
  • #3 16210121
    98mati11
    and what about it?
  • #4 16210517
  • #5 16210557
    T5
    Admin of Cars group
    Help: 1004
    Rate: 4182
    98mati11 wrote:
    the car closes with the key without any problems but the problem is simply not opening when you open it. You can hear the ticking from around the trunk, the direction indicators light up but it will not close the car.
    After all, what is the problem? With closing or with opening?
  • #6 16212644
    98mati11
    error - there is a problem with opening the car.
