[Solved] Audi A3 1.8 (1999) Key Programming: 2-Button Pocket Knife Key Battery Replacement
pro4930 169566 19
How do I resynchronize the remote key after replacing the battery in a 1999 Audi A3?
After replacing the battery, resynchronize the Audi A3 remote by pressing the lock or unlock button on the key and then, within no more than 1 minute, locking or unlocking the car with the key in the driver’s door lock [#5979197] The manual quote says the system synchronizes automatically when the car is opened or locked with the door lock after receiving a radio signal, and then the remote is ready for use again [#5979197] One reply also describes inserting the key into the driver’s door lock, holding it in the closed position, and pressing the close button [#3258050] Another user confirmed that this simple procedure worked in about 5 seconds after battery replacement [#10503643]
  • #1 2520812
    pro4930
    Hello all!
    I have 2 pocket knife keys with two buttons (open and close).
    Audi A3 1.8 car, manufactured in 1999
    The key has stopped working because the battery has died. No reaction after replacement.
    Please help with programming.
  • #2 3258050
    Macio116
    Rate: 29
    I know how to do this. I do not remember exactly so I will have to check the manual for the car because it is described. From what I remember, you need to insert the key into the driver's door lock. When closing the key, hold it in the closed position and press the closing button. If I was wrong, let me know. I will read the manual and write back
  • #3 3711921
    gelus
    Rate: 28
    if I could ask, can you send specific coding instructions for the remote control of the pocket knife to the control unit? manual or with a vaga?
  • #4 5979197
    Macio116
    Rate: 29
    I promised to write exactly so please. Sorry I didn't reply for so long.
    Audi a3 key coding a quote from the user manual:
    If the car cannot be opened or closed with the buttons on the key after replacing the battery using the radio remote control (key), synchronize the device. Synchronization occurs automatically if the car is opened or locked with the door lock after receiving a radio signal. The device is then ready for operation again. End of quote.
    In short:
    Press the closing or opening button on the key and after that, within no more than 1 minute, we lock or unlock the car with the key in the door on the driver's side. After that, the buttons on the key should work
    Let me know if I helped someone.
  • #5 10503643
    danielszel
    Rate: 18
    This information helped me a lot.
    After replacing the battery, the remote control decoded for me and I was about to let the specialist earn PLN 50 for coding, but I thought that I would read on the net and maybe I'll do something myself.
    Well, it worked, it only took 5 seconds and everything is fine. Thanks for your help.
  • #6 10523162
    klosus
    Rate: 8
    Hello, I also have a problem with the key, like a colleague, I tried to program hold the button and then turn the key, but it did not give a result, is there any other way, best regards
  • #7 10947778
    majki_one
    Rate: 10
    I have a similar problem, today I changed the batteries in the remote controls. The problem is that I have a broken insert in the lock from the driver and not at all from the passenger. I tried from the trunk but linden. Is there any other way?
  • #9 14262320
    pi7
    Rate: 30
    The problem occurs when you wait too long with the battery removed, the capacitor is discharged, you can charge it inductively in the ignition switch.
  • #10 15749632
    gemiel
    Help: 79
    Rate: 307
    In the Audi A3, for example, 98r. in the case of a damaged lock insert, the signal can be given manually.
    To do this, unscrew the 3 screws securing the bonnet opening lever and fold back the plastic cover of the driver's door pillar.
    In the brown cube, the two upper wires are the ground control for the lock. It is enough to press a button on the remote control and enter the mass on one of the wires (e.g. through a bulb tester).
  • #11 15915551
    szeryffo
    Rate: 14
    I have a problem with the Audi a3 8p 2004 car. After the holidays, when I came back, it turned out that the battery was discharged. The first thing I did was replace the batteries in the remote control - it did not help, then I managed to open the hood and connect another battery - it did not help. The key in the door does not open the car (possibly a damaged lock). My hood is open, the battery is full, and I cannot open the door. The handle on the inside is "soft" and does not open the door, the buttons to open the door from the inside are inactive. The key probably decoded by replacing the battery. Is there a way to code the key or open the car in a different way? Please, give me a suggestion and help.
  • #12 15930801
    adamski123
    Help: 46
    Rate: 250
    Buddy, drive to someone that would program the remote control via obd2, if you have active, you will open the door and repair the lock or cylinder
  • #13 16907663
    wojteczek12
    Rate: 15
    I have a similar problem, only that it is A3 8L from 2000 (three-door) and the door handles do not have inserts, the central one does not respond to the remote control and the door is opened with a key (pocket knife with two buttons -) through the boot door insert, I will add, that the diode in the key reacts. How to program it in this case?
  • #14 16908491
    adamski123
    Help: 46
    Rate: 250
    Hello, to program the remote you must have two keys, if you do not have one key to the ignition and disassemble the driver's door (but you probably have to disassemble the door anyway because the cylinder does not work) unscrew the lock and close it with a screwdriver and open it, if not the towers how to synchronize the remote then after Christmas you I will send a description of greetings
  • #15 16908501
    wojteczek12
    Rate: 15
    OK thank you. I will wait for a description after Christmas, because I don't really understand how to do it.
    Happy Holidays and best regards
  • #16 17972365
    janekzawo
    Rate: 46
    I have a similar problem, after replacing the battery (Audi A3 from 2008), I can open and close the car, but I cannot start the car, the word SAFE appears on the display and when it starts up for the first time, it goes out after a while. In the manual, I read that you need to insert the key from the driver's side, close the car with the door closing or opening button pressed, but it does not help, the word SAFE is still there.
    Anyone have any idea ???
    Janek
  • #17 17972485
    coperfild
    Help: 291
    Rate: 1697
    You have not lost the transponder from the key?
  • #18 17972503
    janekzawo
    Rate: 46
    after opening the flap, I only have a socket for the battery, the rest are screwed together and built-in, what does the transponder look like and what can be done if it wasn't?
    Theoretically, it should not fall out, because the remote control was not unscrewed, only the battery was replaced
  • #19 17974416
    janekzawo
    Rate: 46
    maybe there is an option to synchronize the second key (the first one works without a problem) or coding, e.g. inserting into the ignition and some combination of opening / closing buttons?
  • #20 18007851
    janekzawo
    Rate: 46
    I was in the guy with the keys - he coded the key - cost 150 zlotys
The discussion revolves around key programming and battery replacement for the Audi A3 1.8 (1999) pocket knife keys. Users share methods for synchronizing the remote after battery replacement, emphasizing the need to lock or unlock the car using the driver's door lock within a minute after pressing the key buttons. Some users report success with this method, while others face issues with damaged locks or non-responsive keys. Additional suggestions include using the Vag com program for remote adaptation and troubleshooting techniques for broken lock inserts. The importance of the transponder in the key is also highlighted, with users discussing potential solutions for keys that fail to start the vehicle after battery changes.
