Lenovo Flex 15: Touch Functionality Unresponsive, Matrix Functional - Possible Mechanical Damage?
swiderEK1 6363 5
  • #1 16214371
    swiderEK1
    Rate: 17
    Hello, my lenovo flex 15 fell in touch, the matrix works correctly. The laptop warranty has expired recently. Is it strange that the touch fell and the matrix did not?
    1. was windows 10 - I came back to 8 and it did not help
    2nd format did not help
    3. updating the drivers did not help
    it seems to me that this is mechanical damage, did anyone have a similar problem? Is the whole matrix to be replaced? I can see that 5 cables come out from under the top cover, two of which are antennas - is this a polka cap for dies and is there a separate cable? Maybe rubbed off? Is the whole matrix to be replaced?
  • #2 16227996
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    4. The swap matrix was changed?
  • #3 16228062
    swiderEK1
    Rate: 17
    I haven't changed anything since the novelty, the computer has not been turned up.
    I have no other matrix to check - if no one tells me what could be the reason then the service will be testing
  • #4 16228137
    boro1234567
    IT specialist
    Help: 2772
    Rate: 1540
    The website will have a matrix.
  • #5 16228376
    lisek
    Service technician RTV
    Help: 6350
    Rate: 6880
    Connect to a laptop or tablet mouse and set the "gestures" so, there was selected the "use finger as input device".
    Often this solves the problem.
    Dotyczy min. Lenovo IdeaPad Flex 15 (DA0ST6MB6E0 REV:E)
    czyli platforma Quanta ST6
    __________________
    Czasem nie wył. (jest kombinacja klawiszami) w Win10 swojego Touchscreen (Urządzenia HID) > patrz w Dispatcher
    Masz podręcznik użytkownika tego laptopa?!
    - nie > to zassaj ze strony Lenovo
    W panelu sterowania T-screen jest rozpoznawany?
    - np. Win8 to skróty do : Tablet PC and Handwriting
    _______________________
    * lub czasem zmiana Bios na nowszy pomaga. Link
    Jak nie to szukaj nowej matrycy.
    p.s
    Reinstalled the system to Windows 7 x64
    After a "dream" Touch ch stops working and the control panel disappears menu settings Tablet PC Settings but noticed the feature , if searching to enter the "Tablet PC Settings" in the opened window, in the tab Display press the button Setup and "touch" in touch then he begins to rotate
    F6 - Enable/disable the touchpad and buttons the touchpad/ touch screen
    Np. Lenovo G500s Touch (platforma Compal LA-9901p)
  • #6 16229727
    swiderEK1
    Rate: 17
    I have something like:
    TOUCH SCREEN COMPATIBLE WITH HID
    which is enabled, is found again after deleting and searching again
