Configuration Neostrada / Orange - What parameters should I choose for configura
alik321 9684 2
  • #1 16216249
    alik321
    Rate: 31
    Good morning, does anyone know what parameters Neostrada / Orange works on the Asus DSL-N12E Router (I will add that I was looking on the Internet and there are different)
    VPI:
    VCI:
    Service category: UBR / CBR / RT-VBR / NRT-VBR
    PCR:
    IP version: IPv4 is set
    Connection type VAN: PPPoA / PPPoE (this is how it was set up)
    UPnP enabled? : Yes No
    802.1Q Enabled: yes / no VLAN ID:
    Tryp tunneling: PPPoE LLC / PPPoE VC-MUX / PPPoA LLC / PPPoA VC-MUX
    Default route: yes / no
    MTU: 1492 is set
    PPP Authentication: Auto / CHAP / PAP
    Thank you in advance for your help :)
  • #2 16216450
    salmon
    Help: 435
    Rate: 262
    Is it really difficult to find answers in google, if not directly on the Orange website?
    1. the result of the query to google "orange dsl connection parameters":
    http://www.orange.pl/kid,4004241979,id,400424...laczyc-i-skonfigurowac-modem,helparticle.html
    As for the differences - the parameters do not write permanently, you can always change, test ...
  • #3 16237816
    grenrex
    Rate: 21
    Hello to the beginning, you can leave all the default settings. If this does not work, try then configuring the router using the orange page (remembering what technology you use neo).
