Sagecom CS 50001 Orange Funbox - configuration without neostrada
MES Mariusz 21954 6
  • #1 16615564
    MES Mariusz
    Level 36  
    Help: 8
    Rate: 224
    I changed operator, after Orange I had a device: Sagecom CS 50001. It is a decent Acces Point / Router with Gigabit ethernet and VoIP ports. I would like to use it / configure it as a router (on WAN connect RJ45 from the current provider, and have LAN behind, but better, disable DHCP, connect the cable from the provider to one of the LAN ports, and use the device as an AP (bridge between cables and WiFi).
    The problem is one: after resetting the device, the device's factory page is not displayed, only the customized Orange menu. If I don't give my login and password to the neostrada, I won't go any further. What's worse, I would have to have an ADSL line (I could connect at least on the test data) and I don't have one.
    Is there a chance to bypass the Orange menu in any way, so that without entering the username and password to Neostrada, I can get to the full configuration menu of the device?
    Thanks in advance, beautiful for your help.
    Mariusz
  • #2 16616264
    Heinzek
    Help: 554
    Rate: 494
    You did not return a device that you do not own. Orange only leases them.
    MES Mariusz wrote:
    It's pretty decent
    HeHe :)
    You can enter the standard: registration(_at_)neostrada.pl password registration
    You can go to a neighbor / friend who has the adsv / vdsl line for a while, connect the equipment for a moment and log in to the configuration page.
    I don't know another one.
    This should work, but you won't run VoIP.
  • #3 16616371
    MES Mariusz
    Level 36  
    Help: 8
    Rate: 224
    Orange doesn't rebuke or bother, so I won't give them gifts ;-) . Who will pay me back for gas? ;-)
  • #4 16616379
    Heinzek
    Help: 554
    Rate: 494
    May they not remember. Somewhere there is a penalty of PLN 300, I think.
    Like what you give it back :)
    As I wrote, you will do nothing more. There is no alternative.
  • #5 16616808
    simhak
    Help: 109
    Rate: 336
    There is a record in the regulations.
    Orange will wait three years and then sell the debt to the relevant companies, and those who are known in the default hearing will give the bailiff a job. And then to give over a thousand zlotys.
  • Old Orange routers are rarely reclaimed
    #6 16617848
    MES Mariusz
    Level 36  
    Help: 8
    Rate: 224
    Generally a dead record, because while it is legal, in fact no one is collecting old equipment. TP has distributed millions of LiveBoxes over the decade, and despite the fact that there was a record there, that the equipment belongs to TP and no one collected it after that.
    Of course, it is good to have on hand and keep it just in case, while practice shows that no one collects anyway, and the cost of the device is included in the subscription.
  • #7 17275166
    arcis
    Yes, there is auto-configuration in funbox and it spits js scripts without adsl.
    I logged in, and they want PLN 300 for the roter, and once there were liveboxes for PLN 10 each.
    Gentlemen, first of all, Orange dims something, you get dns other than those set in the funbox ..
    nothing on the card. vpn only approx.
    Check e.g. at https://ipleak.net
    Orange Experts say they don't know what's going on ... hehe
The discussion revolves around configuring the Sagecom CS 50001 router, previously used with Orange, for a new internet provider without access to the original Neostrada login credentials. The user seeks to bypass the Orange-specific configuration page to set the device as an access point (AP) by disabling DHCP and connecting directly to the LAN. Responses suggest using default login credentials or temporarily connecting the device to an ADSL line to access the configuration. Concerns about potential penalties for not returning the leased device are also mentioned, along with the challenges posed by Orange's auto-configuration and DNS settings.
