Peugeot 508 - Electric Scheme for Non-Functional Folding Mirrors: Fuse Check, Glove Box
Asdzronk 39765 12
Why won’t the Peugeot 508’s power-folding mirrors unfold even though the indicators and mirror adjustment still work?
The mirrors likely won’t unfold because the control panel/switch unit is the wrong version and does not have the folding/unfolding selector; replacing it with the correct panel fixed the problem [#16224532][#16229134] If the mirrors have never worked before, they may also need to be enabled with PP2000 or DIAGBOX [#16224053] Another suggested check was for broken wires in the mirror hinge/joint area, and if a plus wire shorts there it can blow the fuse for both mirrors [#16217699][#16221738]
  • #1 16216500
    Asdzronk
    Rate: 50
    I have a problem with the Peugeot 508. The mirrors do not unfold (right and left).
    Does anyone have an electric scheme?
    Fuses behind the glove box checked. By auto-dates there are fuses responsible for heating, mirror control.
  • #2 16217699
    markovip
    Help: 143
    Rate: 187
    In such automatic mirrors they like to break wires in joints. I would start by checking this.
  • #3 16217729
    wqq
    Help: 48
    Rate: 173
    First, connect it with the appropriate interface (PP2000) and check what hurts it ...
  • #4 16221458
    Asdzronk
    Rate: 50
    And if the wires are damaged in one mirror, the other will also stop working?
    There are no errors in autocom and texie. I do not have anything dedicated to a Frenchman. I will call the area for this PP2000.
    This scheme of ele. no one will drop?
    I will add that the direction indicators in the mirror and ele. mirror adjustment works OK.
  • #5 16221536
    Przemek2011
    Help: 15
    Rate: 81
    Were the mirrors automatically unfolded beforehand?
  • #6 16221592
    Asdzronk
    Rate: 50
    Yes - the mirrors were folding and folding earlier.
  • #7 16221738
    markovip
    Help: 143
    Rate: 187
    If the plus wire y blinked and did a short circuit then the fuse for both mirrors will blown.
    It's normal.
    A colleague will not see a worn wire there. You have to undress the mirrors ...
  • #8 16221903
    Asdzronk
    Rate: 50
    All fuses have been checked under the storage compartment and in the engine compartment. I'll check the fuses under the steering wheel tomorrow. did they leave 508 without an ele. folding mirrors?
  • #9 16224053
    Przemek2011
    Help: 15
    Rate: 81
    Why does a friend ask about it? Were the mirrors never made up before and a friend trying to start them now?
    If the mirrors have never worked before, they should be activated with the PP2000 diagnostic interface or via DIAGBOX.
  • #10 16224532
    Asdzronk
    Rate: 50
    Thanks for the answer. I think I found the reason.
    I exchanged buttons controlling windows and mirrors, but now I see that I probably bought not those, because there is a lack of slider on the slider from the choice of mirrors down that is responsible for folding and unfolding the mirrors.
    I have already ordered the buttons with the down arrow on the allegro.
  • #11 16225188
    wqq
    Help: 48
    Rate: 173
    And it was so right away that we would not be wondering what could have got off there ...
  • #12 16225263
    Asdzronk
    Rate: 50
    I'll set up the right switches and let me know if the case is settled
  • #13 16229134
    Asdzronk
    Rate: 50
    Subject to closing!
    After replacing the control panel with windows and mirrors, the mirrors fold and unfold.
The discussion revolves around a malfunction in the electric folding mirrors of a Peugeot 508, which do not unfold. The user has checked the fuses located behind the glove box and in the engine compartment but is seeking an electric scheme for further troubleshooting. Responses suggest checking for damaged wires in the mirror joints, using diagnostic tools like PP2000 or DIAGBOX, and ensuring the correct control buttons are installed. The user later identifies that the issue was due to incorrect replacement buttons lacking the necessary slider for mirror control. After replacing the control panel, the mirrors function correctly again.
