Peugeot 508 2011 - Error B1328 13 Driver Fault: Rear Window, Mirrors & Seats Not Heating
adamski123 9693 7
  • #1 16891905
    adamski123
    Help: 46
    Rate: 250
    Hello colleagues, I have a problem with the Peugot 508 2011, it does not heat the rear window, mirrors and seats after the diagnosis, error b1328 13 driver fault
    defrosting the rear window or mirrors. Has anyone worked on a similar topic, thank you in advance for your help, best regards
  • #2 16894681
    adamski123
    Help: 46
    Rate: 250
    Hello, no one of my colleagues has changed such a topic in the peugot 508 that the heating of the mirror seats and the rear window do not work
  • #3 16897535
    dziesiaty1
    Rate: 37
    Hi!
    Peugeot writes on error b132813:
    Part of the circuit is open.
    Suspicious zones:
    1.BFH3 cabin fuse box (unless in the passenger glove box)
    2.BSI
    3.Electrical harness
    I would check fuses, mirror heaters, window contacts, if not, I would look for a diagram.
    It seems to me that the heating of the seats is another fault in the 508, unrelated to that one, namely a very often burned-out driver connector, where the driver is a plastic black box under the left and right seat to which there is a 10-pin connector.
  • #4 16898023
    adamski123
    Help: 46
    Rate: 250
    Hello, thanks, buddy, for your interest in the topic, I will check it, let me know around Wednesday.
  • #5 16919698
    adamski123
    Help: 46
    Rate: 250
    Hello today, I just looked at BFH3 and it looks like everything is ok there. check the greetings
  • #6 16920404
    dziesiaty1
    Rate: 37
    Hi!
    Enter the last 8 characters of the chassis number, if I can do it, I will enter the diagram, what about the modules under the seats?
    dziesiaty1
    Rate: 37
    Hi!
    The relay for heated windows and mirrors is located in the cabin BFH3 fuse box under the passenger glove box. From the relay to the F1 40A fuse to the glass, to the F2 7.5A fuse for heating the mirrors. The BFH3 has a black 46-pin connector where the G1 pin is on the glass, and the H6 pin is on the mirrors.
    So the BFH3 power supply comes to the 1st pin of the 2-pin black connector, it should be constant +. This power is supplied from the protection module on the battery under the black cover, from the F1 80A fuse from the battery.
  • #8 16970903
    adamski123
    Help: 46
    Rate: 250
    I close the topic, I would like to thank my colleaguex10 for his willingness to solve the topic
The discussion revolves around a 2011 Peugeot 508 experiencing issues with heating the rear window, mirrors, and seats, indicated by error code B1328 13. Users suggest that the problem may stem from an open circuit, with potential areas of concern including the BFH3 cabin fuse box, BSI, and electrical harness. Specific components to check include fuses, mirror heaters, and window contacts. A common issue noted is a burned-out driver connector under the seats. The relay for the heated windows and mirrors is located in the BFH3 fuse box, with detailed instructions provided for tracing power supply and connections.
