Leaking Radiator Cone During Heating Season: Thermostat-Related Issue?
paka1285 10314 16
How can I stop a radiator from leaking at the cone/thermostat connection when the thermostat is turned on?
You can usually fix it by isolating the radiator, setting the head to 0/*, and then tightening or reassembling the connection; if you are unsure, call maintenance because overtightening can make the leak worse [#16225237][#16224303] Before working on it, close the shut-off valve(s) on the radiator—ideally both flow and return [#16225237][#16234128] If the leak is at the gasket area, clean the seating surfaces thoroughly, replace the gasket with a new one, and optionally use a little sealant; the cone seals metal-to-metal, so it must not be damaged [#16234128] On this type of radiator the thread on that side may be left-hand, so check the thread direction before tightening [#16225237][#16232930] The thread starter later confirmed the practical fix was to close the return valve, set the thermostat to 0, remove and drain the radiator, tighten the plug/cork, and reinstall it [#16242915]
  • #1 16224220
    paka1285
    I have a problem with a leaking radiator. It drips at the cone when the thermostat is off, when it is unscrewed, nothing leaks. I currently have a heating season in the block, so I don't know if I can do anything about it. Thank you in advance for the hint ;)
    • Leaking Radiator Cone During Heating Season: Thermostat-Related Issue? 20170124_144522.jpg (1.12 MB) You must be logged in to download this attachment.
    kortyleski
    Help: 957
    Rate: 3847
    If you have some practice, you can try to gently tighten. But there is a risk that it will let go completely and there will be a hot pool in the apartment. The second option is to call a maintenance technician from adm
    brofran
    Help: 648
    Rate: 1399
    Tighten these 2 nuts with a flat spanner (24 mm, if required).
  • #4 16224638
    paka1285
    It is impossible to tighten, it is screwed to the maximum. Maybe this radiator cap gasket needs to be replaced?
  • #5 16224712
    Waldemar z Kaszub
    Help: 111
    Rate: 467
    As a rule, it can be tightened a little because it is brass and it gets dented. But when indeed already
    it risks cracking and a significant problem.
    You have to contact the administration and make an exchange.
    And then mark the place of leakage on the photo with the arrow.
  • #6 16224778
    tomek3108
    Help: 8
    Rate: 53
    Sometimes leaks are caused by stalling too much by half-screw, you can put something on one side and tap on the opposite to release the stress. Sometimes it helps though not always.
  • #7 16224869
    paka1285
    The leak is in a red circle. Leaking Radiator Cone During Heating Season: Thermostat-Related Issue?
  • #8 16225024
    brofran
    Help: 648
    Rate: 1399
    Well, you should loosen the right brass nut, then tighten the white nut and tighten the brass nut again. A delicate and risky operation.
  • #9 16225027
    REMUR.
    Help: 143
    Rate: 254
    You have marked too large area, it flies in the yellow field (flare) or on the gasket in the blue field?
  • #10 16225196
    paka1285
    Drips into the blue field on the seal.
    When the thermostat is off, nothing works when it is turned on
  • #11 16225237
    Nargo
    Help: 45
    Rate: 206
    Is there a shut-off valve at the bottom of the radiator?
    If so, just turn the return valve on, set the head to 0 or * and then without much stress you can loosen the screw connection from the thermostatic valve, tighten the radiator plug (attention on this side is probably the LEFT thread) and screw the screw connection.
  • #12 16232830
    paka1285
    Yes, there is a return valve. I will try as you say and we will see.
  • #13 16232930
    pablowp1
    Help: 46
    Rate: 144
    Yes, there is a left thread. And leaks in these radiators and in these places are almost standard.
  • #14 16234128
    Zbigniew Rusek
    Help: 394
    Rate: 1537
    This is not an easy matter. The shut-off valve must be turned off (flow and return !!!). Unscrew the radiator cap (check the thread direction - it used to be so - in cast iron - that the blind plugs were left, the plugs from the power supply side - right), clean the plug collar thoroughly from rubbish and rust (it must be smooth and clean), clean the collar heater. Replace the gasket with a new one (obligatory) and additionally lubricate it with some sealant (e.g. liquid seal - type of silicone). Tighten firmly (but do not break the thread, because it is an aluminum radiator and not a cast iron radiator). Next, clean the thread on the nipple, screw the valve, apply thread paste, tow and paste on the tow again and screw this nipple into the radiator cap (exactly, to the end). Only then tighten the valve nut. Attention. Clean the cone of dirt well. It cannot be upholstered (therefore it cannot be thrown onto a concrete floor or hit with steel or cast iron objects), because it is sealed only "cut", i.e. one part is fitted (lapped, polished) to the other and when the cone is damaged, tight tightening is almost impossible (there is no seal).
  • #15 16235922
    Nargo
    Help: 45
    Rate: 206
    Looking at the leak, I dare say that the plug was not tightened tightly, and when screwing the screw connection it became loose and the installer did not notice it. Fachman will do it in 30-60 min as the book writes.
    This leak can be quickly removed in 5 minutes, more time will go down the stairs to the apartment :D .
    Edit: A colleague wants to remove it the cheapest, as I wrote above, there is nothing to exaggerate the problem.
  • #16 16236094
    r103
    Level 37  
    Help: 280
    Rate: 942
    As cheap as possible. In the block. In general, the Central Heating installation, as the name suggests, is a common part of the block. So it deals with this so-called - management, administration or whatever - and all repairs are a matter for those authorities.
    The owner / tenant of the flat can se bury wicie where.
  • #17 16242915
    paka1285
    I dealt with it. I closed the return valve and set the thermostat to 0, unscrewed the radiator, drained the water and removed the radiator. Then I tightened the cork calmly, put the heater back on, tightened it all and everything was fine :D
✨ The discussion revolves around a leaking radiator cone during the heating season, with the user noting that the leak occurs when the thermostat is off. Various responses suggest potential solutions, including tightening nuts, replacing the radiator cap gasket, and ensuring proper sealing of connections. Users recommend checking for a shut-off valve, cleaning the plug collar, and using sealants to prevent leaks. The importance of careful handling to avoid further damage is emphasized, and one user successfully resolved the issue by draining the radiator and tightening the cork. The consensus is that leaks in these radiators are common and often manageable with proper maintenance.
