Celcus TV Unsupported Video Format: Channel Connection Antenna Fix
Xsadasko 15621 9
How can I fix a Celcus TV showing "unsupported video format" after scanning channels from an antenna?
Your TV is receiving a signal in a format it cannot decode, so the practical fix is to use an external decoder connected via HDMI. The thread points to a country/standards mismatch: the TV worked in England, where MPEG-2 is used, but in Poland the broadcasts use MPEG-4, which causes the "unsupported video format" message [#16229067] Another reply notes that the TV model appears to support only MPEG-2 / analog-style reception, so it will not decode the current signal directly [#16228246][#16228438] In other words, the antenna setup itself is not the problem; the TV needs a set-top box/decoder compatible with the local broadcast format [#16229067]
  • #1 16228045
    Xsadasko
    Rate: 9
    Hello, I have a celcus tv and connected it to the antenna, it nicely searched for channels, wants to turn on a channel and I get information that it is an unsupported video format. Please advice how to fix it.
  • #2 16228118
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 273
    Xsadasko wrote:
    i have tv celcus
    Maybe a more precise type, some model number ..
    since when do you own previously operated?, in Poland or ...?
    Xsadasko wrote:
    I connected it to the antenna
    Which, individual, some collective, cable? (antenna connection is often called CATV network connection).
  • #3 16228180
    Xsadasko
    Rate: 9
    The model is dled32167HD, tv was used in England, it worked without problems. Analog TV is connected, room antenna.
  • #4 16228246
    LeDy
    Help: 1995
    Rate: 2946
    There would certainly be another message on analogue. It's MPEG2.
  • #5 16228313
    Olek II
    Moderator
    Help: 452
    Rate: 414
    We do not have analog television. Change the reception parameters in the menu.
  • #6 16228386
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 273
    From the instructions found on the net:
    https://www.manualslib.com/manual/1066784/Celcus-Dled32167hd.html?page=4#manual
    it follows that this is only an analogue, in my opinion you will have to buy a decoder.
    I wonder what he was connected to in England, some analog cable?
  • #7 16228438
    kazikszach
    Help: 516
    Rate: 1105
    You read something wrong, it has a DVB-T tuner, they just didn't say what.
    The message shows that only MPEG-2.
  • #8 16228524
    Włodzimierz Wojtiuk
    Level 32  
    Help: 231
    Rate: 273
    Well, they don't brag about it on the front pages ;-)
  • #9 16228919
    Xsadasko
    Rate: 9
    In England it was connected to a cable TV (worked without a problem)
  • #10 16229067
    kazikszach
    Help: 516
    Rate: 1105
    Yes, but now you are in Poland.
    In England, the MPEG-2 compression system is used, and in our case MPEG-4, hence the message on the screen.
    As previously recommended only an external decoder connected via HDMI.
The discussion revolves around a Celcus TV (model DLED32167HD) that is displaying an "unsupported video format" error when attempting to access channels via an antenna connection. The user previously operated the TV in England without issues, where it was connected to cable TV. Responses indicate that the TV supports MPEG-2, which is compatible with the UK system, while Poland uses MPEG-4. To resolve the issue, it is suggested that the user may need to adjust reception parameters in the TV menu or purchase an external decoder to facilitate compatibility with the local broadcasting standards.
