Firmware update needed: Celcus DLED32167HD (Vestel 17MB82-1a)
gillas 18096 8
  • #1 17299972
    gillas
    Mark: CELCUS
    Model: DLED32167HD
    Chassis (main board, components): MB: 17MB82-1a, PSU: 17IPS19-5
    LCD Screen/Panel (if exist): VES315WNDL-01
    More informations:
    Please help me to download the correct firmware for this TV. I replaced the PSU and it now starts up only if I freeze the chips with compressed air.
    I believe that I just need to re-flash the correct firmware. I do not have any EEPROM tools to be able to download the firmware from the chip itself
    Thank you for your help in advance.
    Steve Firmware update needed: Celcus DLED32167HD (Vestel 17MB82-1a) Firmware update needed: Celcus DLED32167HD (Vestel 17MB82-1a) Firmware update needed: Celcus DLED32167HD (Vestel 17MB82-1a) Firmware update needed: Celcus DLED32167HD (Vestel 17MB82-1a)
  • #2 17307380
    jean0791
    Help: 75
    Rate: 232
    SW update via USB
    17MB8X Core Software Update
    1. Please copy the file to USB device. There is no need to use any specific folder.
    • upgrade_loader.pkg
    2. Turn power to OFF by mechanical switch or removing AC plug and plug the USB to TV.
    3. Keep pressing and holding “OK” key from remote control and at the same time turn power to
    ON by mechanical SW and hold OK pressed until the standby led blinks very rapidly.
    4. SW update starts automatically when the led starts blinking.
    5. SW update is completed after led blink is done.
    * After core update, user/profile settings and panel files do not change.
    * After Core update, bootloader/mboot version will be updated.
    * SW version can be controlled from other settings or service menu.
    • upgrade_loader.rar (9.03 MB) You must be logged in to download this attachment.
  • #3 17312722
    gillas
    Amazing! My TV is working again now. Thank you so much :-)
    Steve
  • #4 17631169
    zony
    Hi
    Will this firmware work with a Polaroid P24LED12.
    Power board is a Vestel 17IPS61-2, main board is a 17MB82-1a.
    I have the standby LED flashing.
    Many thanks
    Tony
  • #5 17632763
    jean0791
    Help: 75
    Rate: 232
    17MB8X Core update should work for Polaroid P24LED12 with main board 17mb82s-1a.
  • #6 17718155
    idaddi
    Rate: 17
    imag center
  • #7 17775931
    wadii
    Rate: 39
    no picture
  • #8 20031992
    emudem
    Thank you, perfect fix!! in TV nevir nvr-7502-32hd
  • #9 21143887
    wadii
    Rate: 39
    merciiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii 100/100 ok
✨ The discussion revolves around the need for a firmware update for the Celcus DLED32167HD TV, which utilizes the Vestel 17MB82-1a main board and 17IPS19-5 power supply. The user, Steve, reported that after replacing the power supply, the TV only operates when the chips are cooled with compressed air, suggesting a firmware issue. A response provided a step-by-step guide for performing a software update via USB, which successfully restored the TV's functionality. Additional inquiries about firmware compatibility with other models, such as the Polaroid P24LED12, were addressed, confirming that the same firmware could be applicable.
