Scania R 420: BMS 2794, EMS 5635, GMS 11050, iCL 1280 - Decoding Scania Error Codes
maxtor1234 21126 11
What do the Scania fault codes BMS 2794, EMS 5635, GMS 11050 and iCL 1280 mean?
EMS 5635 is a radiator fan fault: the fan speed deviates from the value requested by the control unit, usually due to a faulty fan clutch, too little or no oil in the clutch, or changed oil viscosity. Check that the fan has slight resistance when turned by hand; if it spins freely, the clutch is damaged, and also inspect for oil leakage from the fan clutch [#16238474][#16429580] One reply adds that cold weather can change the oil viscosity and trigger the fault [#16238827] The thread did not provide a decoded meaning for BMS 2794, GMS 11050, or iCL 1280. A later reply claimed all the listed errors could come from engine controller damage, but no diagnostic details were given [#19485503]
  • #1 16237495
    maxtor1234
    Rate: 84
    Please read errors in Scania. Thanks in advance.
    BMS 2794
    EMS 5635
    GMS 11050
    iCL 1280
  • EMS 5635 indicates faulty radiator fan clutch engagement
    #2 16238474
    Cobrat
    Help: 35
    Rate: 501
    EMS 5635 - radiator fan error
    Fault :P the speed of the radiator fan deviates from the speed set by the control unit.
    Cause:
    - Error in the fan clutch.
    - Too little or no oil in the fan clutch.
    - The oil viscosity in the fan clutch has changed.
    Notes: The fan clutch is not working properly, reducing cooling capacity. Driving at high power for a long time is not possible.
    Corrective Actions:
    Check the fan clutch, you should feel a slight resistance when turning the fan by hand. If the fan can be turned freely, the clutch is damaged and also check that there is no oil leakage from the fan clutch. Oil leakage indicates clutch failure.
  • #3 16238827
    maxtor1234
    Rate: 84
    There is a possibility that the oil changed viscosity due to frost.
    Added after 5 [hours] 32 [minutes]:
    And the rest of the errors are from what?
  • #4 16241838
    maxtor1234
    Rate: 84
    Nobody can read this?
  • #5 16422236
    TomasAGC
    Help: 13
    Rate: 210
    I have a problem with Scania R 2010 opticruse, the car threw even gears while driving, the gearbox was checked half-gears, the whole set. new, seals. Now the car sometimes loses gears, that is, I want to switch, for example, from 3 to 4 while stationary, it appears that it waits for the gear to switch, the box switches, but it will return to 3 or throw out errors, gms14081, gms14061.
  • #6 16429580
    darfur5
    Help: 267
    Rate: 1715
    From the EMS error 5635 (as Cobrat described to you) there is a problem with the fan, there is too little or no oil or the viscosity of the oil has changed. Turn the fan (by hand), if you feel resistance, that's OK. if there is no resistance, replace the clutch.
  • #7 16488816
    maxtor1234
    Rate: 84
    The fan has resistance.
    I don't want to clutter the forum with new topics and I have some bugs so I'll write them here
    Ems 11176 11182 4106 4108 5635.
    Thanks in advance
  • #8 16489094
    mariomalinie
    Level 19  
    Help: 32
    Rate: 166
    Thanks in advance
    Give buddy the EMS driver number
  • #9 16490704
    darfur5
    Help: 267
    Rate: 1715
    EMS 11176 is a NOx Control Info Code and cannot be cleared, but will disappear by itself if inactive for 400 days.As more precisely it indicates exhaust emission fault codes, the control unit has generated faults in the SCR system. EMS 11182; this code indicates that the control unit has detected fault codes related to the monitoring of the NOx level.
  • #10 19390005
    Rafal19840111
    So if I have the same problem, I have to wait 400 days, the indicator light will disappear and the message about high exhaust emissions
  • #11 19390044
    darfur5
    Help: 267
    Rate: 1715
    Do not wait, just look for the cause, connect the computer and check the system.
  • #12 19485503
    Wojtek21ols
    All errors you provide result from damage to the engine controller. PLN 1200 repair and all errors have disappeared. I was tired for over 3 months exchanging everything for errors and they did not disappear
The discussion focuses on decoding error codes for the Scania R 420, specifically BMS 2794, EMS 5635, GMS 11050, and iCL 1280. The EMS 5635 error indicates a radiator fan issue, potentially caused by a malfunctioning fan clutch or oil viscosity changes. Corrective actions include checking the fan clutch for resistance and inspecting for oil leaks. Other errors mentioned include EMS 11176 and EMS 11182, related to NOx control and exhaust emissions, which may require system diagnostics rather than waiting for automatic resolution. A user also reported issues with gear shifting in a Scania R 2010 model, suggesting broader concerns with the vehicle's electronic control systems.
