LG 49LH590V-ZD Smart TV: Blank Screen on Polsat Program - Flash Plugin, HDMI Solution
jaro033 4281 11
Why does Vision/Wizja TV show a blank screen on my LG smart TV even though it works on a laptop, and do I need HDMI or a Flash plugin?
The LG TV’s built-in browser does not support the Flash/plugin setup required by Vision/Wizja TV, so the stream can appear as a blank screen even though it works on a laptop. The service requirements explicitly mention a Windows computer with Flash, Java, supported browsers, and enabled cookies [#16257504] The plugin is meant for the computer, and the TV’s software will not be changed by installing it [#16257582] The practical workaround is to play it on a laptop/PC and connect that device to the TV via HDMI, or use wireless screen sharing if your setup supports it [#16257547][#16259726]
  • Asking whether missing Flash support requires HDMI input
    #1 16250965
    jaro033
    Hello, today I bought internet television Vision tv and I have a problem because when starting a given program, e.g. Polsat, there is a blank space instead of an image. Does not display program transmission. On a laptop this problem is not there and immediately displays any image when you start any program. Could this be a problem with the flash plugin? From what I heard and I do not know if I heard correctly LG TVs do not have a flash plug.
    The only option is the HDMI cable? Please help
  • #3 16257417
    sosarek
    Help: 9320
    Rate: 15535
    jaro033 wrote:
    I bought internet television. Vision tv
    There is no such thing - it's stream (anyway illegal).
    Z
    Pka, Poznań, 60-850
  • Outdated PC requirements suggest browser-based streaming limitations
    #4 16257504
    1 PAWEL
    Help: 674
    Rate: 1364
    Read the hardware requirements
    5.1. Using the Service is possible provided that the computer equipment used by the User meets the following minimum technical requirements:
    5.2. 1 GHz processor, 512 MB memory, Windows operating system with installed Flash software, Java applets, Adobe Acrobat Reader and decompression programs.
    5.3. use one of the browsers in the version at least as specified, i.e. Google Chrome 27.0.1453.116, Firefox 22.0, Opera 12.15, Microsoft Internet Explorer 10.0.6. or newer with enabled ActiveXPlayer support, updated DRM component, with enabled cookies.
    5.4. Stable connection with a minimum bandwidth of 256KB / s (2Mbit / s). 512KB / s (4Mbit / s) recommended for higher quality (HD) movies.
    5.5. The website is optimized for 1280x800 resolution
    http://wizja.tv/?function=rules
  • LG browser lacks required Flash and Java plugins
    #5 16257523
    jaro033
    1 PAWEL wrote:
    I recommend contacting the LG service
    http://www.lg.com/pl/wsparcie/obsluga-klienta/chat-email
    Chat from Monday to Friday from 8:00 to 17:30
    I wrote with a person from LG that she replied that the browser is not like in a computer and does not support all plugins.
    It's just that I paid on Friday and it works on a laptop and the TV does not, but before I did not have a premium account and I wanted to turn it on either weeb.tv or TV vision, it worked normally.
    Weeb.tv or Vision. TV or other is actually stream and whether it's legal or not, I don't care anymore. I pay for something to have something to watch, and here is a lime. Most Poles abroad are only watching Polish television in this way.
    I got to know it before only as I wrote earlier why earlier when I turned on TV and TV or other internet TV it worked and now after buying a premium account does not work?
  • #6 16257536
    1 PAWEL
    Help: 674
    Rate: 1364
    It is possible that you downloaded advertising material, it will probably be a long time lacking tv to your computer.
    Try contacts with Vision tv.
  • #7 16257542
    jaro033
    I bought for 3 months so I think it should work fine. A friend also bought at the same time that I only have Samsung tv and watch normally.
    So the only option is the HDMI cable from laptop to tv?
  • #8 16257547
    1 PAWEL
    Help: 674
    Rate: 1364
    Samsung new versions have completely different software and browser.
    Or wirelessly if possible.
  • #9 16257562
    jaro033
    I just noticed. Wireless, i.e. how?
    I wrote to Wizja tv and wrote something about the MrKnow tv plugin only that they do not have full rights to it and you have to wait for their plugin.
  • #11 16259726
    jaro033
    1 PAWEL wrote:
    Search how to connect tv wirelessly to a WiFi computer
    https://www.youtube.com/watch?v=e-6XchRLhc8
    This plug only for the computer, software on TV LG will not change only as the manufacturer provides.
    Other
    http://kodiwpigulce.pl/jak-zainstalowac-wtyczke-mrknow-poradnik/
    I searched and mostly writes how to do it from a computer that has windows 8.1 or 10. And from Windows 7 I did not find such a solution.
    Nothing remains cable and that's it.
  • #12 16259732
    1 PAWEL
    Help: 674
    Rate: 1364
    All in all it's even better on cable in terms of reliability and speed of transfer.
The discussion revolves around an issue with the LG 49LH590V-ZD Smart TV displaying a blank screen when trying to watch the Polsat program via the Vision TV internet service. The user suspects a problem with the Flash plugin, noting that the program works fine on a laptop. Responses suggest that LG TVs may not support all browser plugins, and the user is advised to consider using an HDMI cable to connect the laptop to the TV for a reliable solution. Additionally, there are mentions of potential issues with the TV's software and the need for a stable internet connection. Some users recommend contacting LG support or Vision TV for further assistance.
