Philips 49PUS7181 / 12: No Image with HDMI Connection to Digital Polsat HD Receiver
14949 7
  • #1 16515288
  • #2 16517220
  • #3 16519600
    KOCUREK1970
    Help: 3860
    Rate: 5488
    swieczkaPanaNaszego wrote:
    such a message appeared
    This is a tv problem.
    The decoder has a newer version than tv of this security.
  • #5 16519914
  • #6 16519930
    KOCUREK1970
    Help: 3860
    Rate: 5488
    The service will not help here - it's a hardware condition (uploading the latest software will not help either) - in short, you have to buy a new TV.
  • #7 16520159
  • #8 16520198
    KOCUREK1970
    Help: 3860
    Rate: 5488
    I can't because I bought this one in December and spent about 4,000 PLN on it
    From the text above it appeared (this is how I understood it) that you connected YOUR tv with your neighbor's decoder? (that's why I assumed it's your tv's fault).
    Only now questions, what was the decoder at the neighbor's, what platform?
    In general, you describe your actions quite imprecisely - what did you do, how, with what and who only YOU know!
    YOUR decoder checked on a completely different TV?
    It may be necessary to reset both the tv and the decoder to the factory settings (and reinstall them), upload the latest firmware to the tv.
The discussion revolves around a Philips 49PUS7181/12 TV that fails to display an image when connected via HDMI to a Digital Polsat HD receiver, despite audio and menu functionality being operational. The user has tested different HDMI cables and confirmed that the issue persists across multiple receivers. Responses suggest that the problem may stem from a compatibility issue between the TV and the decoder, possibly due to outdated security protocols on the TV. Recommendations include resetting both devices to factory settings and updating firmware, although some responses indicate that a hardware limitation may necessitate purchasing a new TV.
