Choosing Between Magnum VIP 3000 Welder and Chinese Alternatives for Home Use
GOMEZ405 8757 14
What inverter welder should I buy for occasional home use, and is the Magnum VIP 3000 a good choice compared with cheaper Chinese models?
For occasional home use, choose the welder by its real duty cycle and service support, not by the Magnum VIP 3000 name; Magnum is also a Chinese machine, and you should verify who services it in Poland and whether warranty support is actually available [#16260449][#16261338] The thread warns that the important number is the duty cycle at the current you will really use, because budget 120–150A machines often end up around 10–20% duty cycle at high current, and the Magnum’s advertised 160A/60% claim does not mean 160A is continuous [#16259317][#16259382][#16259440][#16259563] If you can, check the exact duty cycle around 100A–140A before buying, since that is the more realistic working range for home use [#16259563][#16259682] For a DIY budget choice, Dedra was mentioned as acceptable, while Spartus was suggested as a somewhat better Chinese option if you can spend more [#16259317][#16260449]
  • #1 16259017
    GOMEZ405
    Hello. I need to buy an inverter welder for housework. Knowing life at the beginning will do a lot and later will be used once a quarter.
    What would you recommend?
    Personally, I'm tuning for Magnum VIP 3000. Maybe Chinese?
  • #2 16259317
    tomjed
    Help: 81
    Rate: 303
    From an autopsy, I can recommend Dedra for DIY. Nowhere can I find info on the work cycle of this Magnum, and this is quite an important parameter. It depends on what you want to weld, because at higher current the duty cycle will decrease. I am not a welder, rather DIY. These inventions are not suitable for larger works, because with 120-150A currents they have cycles of 10-20%.
    pzdr
  • #3 16259325
    GOMEZ405
    I will not receive only dedos in this amount. Must be new and with Fv.
  • #4 16259371
    tomjed
    Help: 81
    Rate: 303
    I know you won't get. Look for the magnum cycle. So that you won't be surprised later that you can weld 100A with a 30-40% cycle.
  • Magnum VIP 3000 offers 160 A at 60% duty cycle
    #5 16259382
    GOMEZ405
    The pages state 160A / 60%
    ... "DESCRIPTION
    Magnum Power VIP 3000 is one of the smallest inverter welders on the Polish market. Dimensions are only 25 x 16 x 10 cm. The weight is 2.7 kg (without welding cables).
    The POWER VIP 3000 can be welded with coated electrodes with a maximum diameter of 4.0 mm. At temperatures up to 25 ° C, rutile-cellulose (pink) electrodes with a diameter of 3.25 mm can be welded in 100% mode, i.e. without interruptions.
    The housing is metal. It has a carrying handle and a shoulder strap. "...
  • #6 16259440
    tomjed
    Help: 81
    Rate: 303
    GOMEZ405 wrote:
    you can weld in 100% mode, i.e. without interruptions.
    Sure, you can ask by what current. Because certainly not 160A ...
    So quickly, in some places the 60% is efficiency
  • #7 16259459
    GOMEZ405
    No ok, just add that once I welded dedera and it got very good. There he writes that it is possible to weld with a 3.25 electrode, which is a conclusion that a current of some 130A. I also found deds for 399 PLN PLN DEDRA DESI190BT 160A IGBT INVERTER WELDING MACHINE
  • #8 16259563
    tomjed
    Help: 81
    Rate: 303
    I don't force DEDRY ... This 160A is probably the same as Magnum. In both cases, the manufacturer does not specify a welding cycle. If you can, take a ride to some DIY store and see the 160A Chinese for welding cycle. Even the "Polish" Bester for 160A has a 10-20% cycle. You won't probably be welding with such a current, but it's good to know what the cycle is for example for 100A, because I suppose that you will work in such a range.
    pzdr
  • #9 16259637
    GOMEZ405
    I found such a plaque
  • #10 16259682
    tomjed
    Help: 81
    Rate: 303
    Hmmm, it looks like you can weld 140A continuously, and 160A you can weld 60%, i.e. 60% welding, 40% gap. But of course not e.g. 6min / 4min ..
  • #11 16260449
    ELSPAW_
    Rate: 9
    Magnum is also a total Chinese and today, unfortunately, one of the more emergency.
    Look at the ideal from the badek company from this lowest shelf - they have good service.
    A little better Chinese is spartus ... but the price.
  • #12 16260533
    GOMEZ405
    Well, he killed me, I thought Magnum was worth something. Magnum Snake, for example, has good reviews. I guess I'll buy a cheap ripper.
  • #13 16261338
    ELSPAW_
    Rate: 9
    It's hard to choose in such a budget. Pay attention to the service so that it is free and preferably in the door to door system, as well as the stability of the distributor in Poland. That this is not a company that has made a one-time purchase and after the sale of the goods disappears, and you will remain with the equipment that you can throw in the bin.
  • #14 16261346
    GOMEZ405
    that's why I thought of Magnum because I have a shop there and a warranty and post-warranty service. I am surprised that Magnum is in welding stores and other riperry and kraft are not. After that, it's hard to find anything on the web about this particular welder. And its lightest weight is 2.7 kg - a bit strange
  • #15 17683105
    swloszczak
    and how did the topic end? I'm also looking for something
The discussion revolves around selecting an inverter welder for home use, specifically comparing the Magnum VIP 3000 with various Chinese alternatives. Users express concerns about the duty cycle of the Magnum, noting that it operates at 160A with a 60% duty cycle, which may not be suitable for all welding tasks. Recommendations include considering the Dedra brand for DIY projects, while cautioning about the performance of Chinese models, which often have lower duty cycles. The importance of service availability and reliability of the distributor is emphasized, as well as the need for a welder that can handle occasional use without significant downtime. Users also mention the weight and portability of the Magnum, which weighs 2.7 kg.
