Inverter Welder for Garage Work: Comparing Magnum Power VIP 4000 vs. Ideal Praktik 205
dawidos726 9579 6
  • #1 16367915
    dawidos726
    Hello, I need an inverter welder for garage work. Well, I was looking for a last time and found two welders, unfortunately I can not find an opinion. Price up to PLN 700 - PLN 800. Maybe you have any other suggestions? I was also looking for a Bester welder, but it was only 135a - not much
    Magnum Power vip 4000 - https://www.olx.pl/oferta/profesjonalna-spawa...4000-elektroda-CID628-IDkXRr6.html#3f67896fe8
    This welding machine seems to be a bit small and fits in the palm of my hand and it puzzles me a little.
    Ideal Praktik 205 - http://allegro.pl/ideal-praktik-205-spawarka-inwertorowa-lincoln-i6621368099.html
  • #2 16368158
    qadam12
    Help: 62
    Rate: 254
    The latter I have / is quite decent.
  • #3 16368658
    mariano8304
    Rate: 21
    Hello and I am dilemma with the choice of a welder for your own needs and so I am not a professional welder and I will use it sporadically. I take two models into account. Parameters almost identical, overall GDMS is lighter and smaller has additional functions such as HOT START, ANTI STICK, ARC FORCE, IGBT TECHNOLOGY. I do not know in which technology SNAKE 200 P works, the information I have chosen from http://spawsc.pl/pl/
    MAGNUM SNAKE 200 P MMA EXAMPLE ON ALEGRO WITH MASK OK 775 PLN
    http://spawsc.pl/pl/linia-snake/23-magnum-snake-200p-mma-5901015100011.html
    or
    MAGNUM SNAKE 200 GDMS ON ALLEGRO WITH MASK OK PLN 780
    http://spawsc.pl/pl/linia-snake/404-magnum-snake-200-gdms.html
  • #4 16369695
    Magister_123
    Level 36  
    Help: 378
    Rate: 974
    I have Snake 200P with a display for three years and I will not say a bad word. Welds even with 4mm electrodes. Small, light and handy. When welding with higher currents on a long extension cable, it must have a cross section of 2.5 mm?!
  • #5 16370841
    mariano8304
    Rate: 21
    I used to have the opportunity to use Snake 200P and it seems to be ok, but Snake 200P
    I did not even physically see. It has additional features and I think it is smaller and almost 2 kg lighter, but if it is a plus for her, I have no idea and that's what I wanted to know. next week I would like to buy.
  • #6 16372760
    jerry1960
    Level 37  
    Help: 285
    Rate: 1562
    I have a Magnum Snake 200 P with a display, previously I had a Bester STA 250. Magnum's advantages light for garage work and ideal in the garden, i.e. a lightweight, good bow archer. I use over 3 years and no problems.
  • Three years of reliable Magnum Snake 200 P use
    #7 16373068
    mariano8304
    Rate: 21
    Yes, buddy, I agree with you and in your opinion it would be worth to buy the model snake 200 GDMS is on the transistors IGBT has additional functions which mute Snake 200 P and probably also is not on IGBT
The discussion revolves around selecting an inverter welder for garage work, specifically comparing the Magnum Power VIP 4000 and the Ideal Praktik 205. Users express their experiences with various models, including the Magnum Snake 200 P and GDMS, highlighting features such as weight, size, and additional functionalities like HOT START, ANTI STICK, and ARC FORCE. The Magnum Snake 200 P is noted for its portability and performance with 4mm electrodes, while the GDMS model is praised for its IGBT technology. Users also mention the Bester welder but find its amperage insufficient for their needs. Overall, the Magnum models receive favorable reviews for light-duty applications.
