VW Touareg 3.0 TDI 240HP: Intake Manifold Flap Position Sensor (Bank 1) P2015 Error & Lambda Probe
r_Lunar 8187 2
  • #1 16262178
    r_Lunar
    Rate: 32
    Hello. Problem in VW Touareg 3.0 TDI 240 horses. In general, there are no problems with driving, it drives normally, smokes normally. But from time to time the check engine light comes on. After deleting the error, the indicator light disappears for some time, but the error does not reset. There was also a lambda probe error but I could not catch it on the computer because it did not appear now.
    Here is the computer record:
    Address 01: Engine Labels: 059-907-401-CAT1.clb
    Control Module Part Number: 7L0 907 401 N HW: 7L0 907 401 H
    Component and / or Version: 3.0TDI EDC17G000AG 0060
    Software Coding: 04210023591F0568
    Work Shop Code: WSC 00160 259 180100
    VCID: 3665569A423017AE7EF-5000
    1 Fault Found:
    008213 - Intake Manifold Flap Position Sensor (Bank 1)
    P2015 - 003 - Implausible Signal - MIL ON
    Freeze Frame:
    Fault Status: 11100011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 203,519 km
    Time Indication: 0
    Date: 2017.02.07
    Time: 19:06:29
    Freeze Frame:
    RPM: 777 / min
    Speed: 0.0 km / h
    Voltage: 14.82V
    Lambda: 0.0%
    Lambda: 0.0%
    Voltage: 0.220V
    Bin. Bits: 00,000,000
    Readiness: 1 1 0 0 0
    Address 01: Engine (7L0 907 401 N)
    14:45:15 Group 003: Exhaust Gas Recirculation (EGR)
    777 / min Engine Speed (G28)
    323.1 mg / str Exhaust Gas Recirculat. (spec.)
    534.6 mg / str Exhaust Gas Recirculat. (actual)
    99.6% Exhaust Gas Recirc. Duty Cycle
    Can anyone tell what and why the problem is and what to do with it? greetings
  • #2 16264737
    buncza
    Help: 10
    Rate: 94
    This is a flap error in the right-hand head intake manifold.
    The flaps are dirty and do not reach their limit values. You can try to clean it with available agents that should be sprinkled into the intake while the engine is running, but if the flaps are very dirty, you can only remove them and clean them manually (or replace them with other ones).
  • #3 16547632
    r_Lunar
    Rate: 32
    The inlet flap drive has been reworked, problem solved
