2007 Passat B6 2.0TDI BMP Engine - P2015 Error Code, Intake Manifold Sensor Issue & Solutions
misior1990 14808 7
  • #1 16908327
    misior1990
    Rate: 9
    I have a problem. I have a Passat b6 from 2007 2.0tdi, engine designation is BMP. I got a P2015 error. The noise suppressor sensor in the intake manifold. I replaced the EGR, the damper, the particle filter was also cleaned. I was with 3 mechanics and my hands are spread. Maybe someone had a similar situation.
    • 2007 Passat B6 2.0TDI BMP Engine - P2015 Error Code, Intake Manifold Sensor Issue & Solutions 20171213_130738.jpg (2.49 MB) You must be logged in to download this attachment.
  • #2 16908341
    szymitsu21
    Help: 342
    Rate: 1292
    Friend, and this is not just about the flaps?
  • #3 16908429
    ociz
    Help: 1378
    Rate: 3475
    Sure, it's a flap adjuster. Yes, that's how you believe in Polish translations of error descriptions ...
  • #4 16908500
    misior1990
    Rate: 9
    Yes, this is the Bmp engine and where is the positioner there?
  • #5 16908584
    adam7009
    Help: 656
    Rate: 1631
    there is, every type has.
    AUTO-ELELEKTRONIK AB
    Linowiec, Lisewo, 86-230 | Tel.: 697XXXXXX (Show)
  • #6 16908586
    misior1990
    Rate: 9
    And you know my friend where is this?
    • 2007 Passat B6 2.0TDI BMP Engine - P2015 Error Code, Intake Manifold Sensor Issue & Solutions 20171223_103931.jpg (2.34 MB) You must be logged in to download this attachment.
  • #7 16908593
    adam7009
    Help: 656
    Rate: 1631
    this is what you call a throttle.
    misior1990 wrote:
    I replaced EGR throttles
  • #8 16908653
    misior1990
    Rate: 9
    Yes I checked 2 pcs and this error still pops up I think I will have to check the cables
✨ The discussion revolves around a 2007 Volkswagen Passat B6 with a 2.0 TDI BMP engine, experiencing a P2015 error code related to the intake manifold sensor. The user has replaced the EGR valve, damper, and cleaned the particle filter but continues to face issues. Responses suggest that the problem may be linked to the flap adjuster or throttle positioner, with recommendations to check the wiring for faults as the error persists despite previous repairs.
