VW Polo 1.2 12v 9n: Addressing P0133 & P0130 Oxygen Sensor Errors & Lambda Probe Replacement
Brzegu 6321 2
  • #1 17417331
    Brzegu
    The "check engine" light popped up.
    On the computer it shows these two errors:
    016517 P0133 - Oxygen sensor 1 (block 1) slow response
    016514 P0130 - oxygen sensor 1 (block 1) malfunction
    The mechanic suggests replacing the first lambda probe in front of the catalyst (from above).
    It says that you have to start with this, but it does not guarantee that the problem will be solved. Someone already had a similar problem?
  • #2 17417392
    peugeot81
    Rate: 60
    It is not certain. Connect to a computer and read the probe parameters while the engine is running. Exchange is the last resort.
  • #3 17417493
    Brzegu
    Where should I look for information on what parameters should the probe go in my car?
