Audi A8 D3 2008: Rear Vehicle Drop, Air Suspension Issues, Compressor Fuse, and Uneven Rise
bartek500 12927 4
  • #1 16262964
    bartek500
    I have a problem with the Audi A8 D3 2008, the problem is with the air suspension.
    For some time now, the entire rear of the vehicle has started to drop. I took the site to the site because the compressor fuse was burning, when the temperatures were below zero and the entire rear of the car was still falling. Of course, before taking the car to the site, I got up and I could drive. When the car landed in their place, it does not rise anymore, but now it is completely right side, front and rear. Best of all, he doesn't want to get up, but the left side is standing normally. When I lift the car, only the left side rises. Please help. The car is standing for a month and you do not know what is?
  • #2 16263032
    olekt2002
    Level 32  
    Help: 147
    Rate: 515
    Have the car serviced (real). You're not likely to do anything yourself.
  • #3 16263100
    Pedros050
    Help: 2471
    Rate: 3927
    Frozen air supply lines from the compressor, the water condenses and does not pump pressure or clogged lines. There is also an option to damage the pneumatics control electronics, but you will not do it yourself, only a trusted car repair shop that knows about such devices.
  • #4 16263418
  • Right-side suspension remains low despite 9-bar compressor pressure
    #5 16264426
    bartek500
    That's why my back could drop all the way because the valves were blocked? I ordered the compressor aso new because mine gave a pressure of 9 bar. The car is in Poznań on the audi service. It's just strange that the entire right side has fallen down and won't get up? And as I wrote, only the left side rises. With this fuse that it burned, what could be the compressor gives a short circuit, that's why it happens Nwm itself, what should I write because I do not know it so well.
    Added after 52 [seconds]:
    There was no water in the pneumatic system.
    Added after 7 [minutes]:
