Audi Q7 2008 3.0 TDI: Suspension Leveling after Battery Replacement - Error 02250 & 31564
bula17 31542 9
How can I fix Audi Q7 suspension leveling errors 02250 and 31564 after battery replacement when the car rises to maximum and won’t adapt?
You need to clear all suspension-related faults, keep every door closed, and check the pneumatics fuses—especially the 40A fuse—because the system will not allow suspension adaptation if the controller still has errors [#16233393] [#16233551] [#16233855] Run a full auto-scan first, since the missing adaptation may be caused by other module errors or communication faults even when the obvious ones look clear [#16233526] [#16233393] One reply specifically reports that a blown 40A fuse caused the rear to rise to the maximum and made height regulation impossible [#16233551] [#16233855] Another reply says the initial idea was that the procedure should be entered through Coding II, but that was not confirmed as the final fix [#16232721] [#16232934] In the end, the original poster reported that when the temperature became positive, everything returned to normal [#16321269]
  • #1 16232709
    bula17
    Help: 52
    Rate: 295
    Hello, I am dealing now with the Audi Q7 problem after replacing the battery 2 km further rose to the max and so was the back and the lack of opportunity to lower, raise Audi Q7 2008 3.0 TDI: Suspension Leveling after Battery Replacement - Error 02250 & 31564
    There were 2 02250 shutdowns due to the valve on time
    and the error of maximal increase, this error is canceled and does not return 02250 returns often.
    I tried to do adaptations but I can not do Security Access 31564 error 22 on a fired and off engine
  • #2 16232721
    szymitsu21
    Help: 343
    Rate: 1300
    Because security access is not it ...
    You enter in Coding II.
  • #3 16232749
    bula17
    Help: 52
    Rate: 295
    Coding 2 not active inability to enter.
  • #4 16232934
    szymitsu21
    Help: 343
    Rate: 1300
    Hmm, I do not do it on a daily basis but now I am starting to wonder if I'm misleading.
    Rosstech says security access, and I was sure coding 11.
    Are you doing ORI VCDS?
  • #5 16233232
    bula17
    Help: 52
    Rate: 295
    Yes, according to ross techa instructions, but nothing like that. Vcds orginal with the latest version. Maybe the problem is not setpoints, but a mistake that I do not know how to bite. As I will give executive elements, it passes everything, the vehicle will be leveled, but it does not do it. It goes through the entire procedure and no errors. Later, it gives the panel a lowering and gives an error.
  • #6 16233393
    Don de Leon
    Help: 51
    Rate: 458
    It will not adapt if any of the doors are open or there is an error related to them, eg communication between controllers.
  • #7 16233526
    bula17
    Help: 52
    Rate: 295
    The door certainly closed all the errors I did not really look at 1. 3. 61. 34 19 in these drivers was clean. I need to download the client and I will do a auto scan
  • #8 16233551
    buncza
    Help: 10
    Rate: 94
    There must be no errors in the controller for the adaptation of the suspension - the system will not let it go.
    Check all fuses - there will be several pneumatics.
    It's possible that one fuse shot. I had a similar situation with VW Touareg - it is not known why, the 40A fuse broke down and the rear was raised to the max, and there was no possibility to regulate the suspension
  • #9 16233855
    Don de Leon
    Help: 51
    Rate: 458
    This fuse 40A, as it falls, generates a power error usually.
  • #10 16321269
    bula17
    Help: 52
    Rate: 295
    Something got cold as the temperature started to be positive everything went back to normal.
The discussion revolves around an Audi Q7 2008 3.0 TDI experiencing suspension leveling issues after a battery replacement. The user reports that the vehicle's rear suspension rises to the maximum height and cannot be adjusted. Error codes 02250 and 31564 are frequently encountered, with 02250 related to a valve shutdown. Attempts to perform adaptations are hindered by security access issues. Responses suggest checking for errors in the controller, ensuring all doors are closed, and verifying the condition of fuses, particularly a 40A fuse that may affect suspension functionality. One user noted that the problem resolved when temperatures rose, indicating potential environmental influences on the system.
