Panasonic TX-49DX600E vs TX-50DXU701: Comparing Matrix Types, HDMI & USB Ports in 20m2 Room
jarrod 2691 10
Which Panasonic TV should I choose for a 20 m² room at 3 m viewing distance: TX-49DX600E with IPS or TX-50DXU701 with MVA and more HDMI/USB ports?
The TX-50DXU701 is the better choice overall; one reply describes it as a good mid-range TV, while noting that its 60 Hz matrix is a compromise if you watch a lot of dynamic sports because it will not add extra motion smoothing [#16267849] More general technical discussion in the thread says movies are still commonly 23.97 fps and that heavy TV motion processing can alter the original cinematic look, so the lower-refresh panel is not necessarily a problem for films and series [#16269150]
  • #1 16267247
    jarrod
    Help: 59
    Rate: 131
    Please help me choose a model. I wonder if:
    http://www.displayspecifications.com/en/model/64374c4
    Panasonic TX-50DXU701
    http://www.displayspecifications.com/en/model/31f18d0
    50dxu701 has more hdmi and usb, and MVA matrices. 49DXU600 has an IPS matrix.
    The more I read about the differences between the matrix types, the less I know.
    1. How big is the room in which the TV is to be located? - 20m2
    2. How far are we from the TV screen? - 3m
    3. How many people sit in front of the TV? - 2.3 people
    4. Are we sitting in front of the screen or also sideways to the screen? - mainly straight ahead, but it can also happen sideways
    5. Should the TV stand or should it hang? - to stand
    6. How does the sun shine in the room? - windows to the east, the sun is shining in the windows until noon, the tv will stand with a window at the back
    7. What kind of TV do you currently have? - 10 years old Samsung LE37M87 FHD
    8. What do we want the TV to have? - 4K, USB playback,
    9. What signal will be connected to the TV? - DVB-T,
    10. What devices? - bluray,
    11. How many hours a day should the TV work? 4-5 hours
    12. Does it happen that you watch only one program for several hours? - no
    13. What kind of programs do you watch the most? - movies, series
    14. Are you going to surf the internet? - sometimes
    15. Are you going to play games - if so, how many% a day? - no
    16. Brand Preference? - Panasonic
    17. Size preferences? - 49-50 "
    18. What annoys you in TV sets? - muddy, artificial image enhancers
    19. Do you watch more in the evenings or during the day? - in the evenings
    20. To what maximum amount do you plan to purchase? - 3,000
    21. How often do you replace televisions at home? - it will be the first one I buy, so it's hard to answer
    22. Do you use internet applications often? - I never had a tv-smart, so I didn't use it
  • #2 16267701
  • #3 16267849
    Ludwik XVI
    Help: 1325
    Rate: 788
    Panasonic TX-50DXU701 is definitely better.
    This is generally a good model for mid-range TV viewers - Except that it has a 60Hz matrix and you have to take an allowance for that if you watch a lot of dynamic sports.
    The TV will simply show what the camera sees - it will not be able to liquefy this material additionally.
  • #4 16268861
    jarrod
    Help: 59
    Rate: 131
    LOCOLOCO wrote:
    These are models with a 50 Hz matrix.
    Have you been to the cinema lately? Videos on Br are still 23.97 fps.
    Any enhancers spoil this 'movie look'. 100Hz pseudo liquidity is a mush for market shopping.
  • #5 16269022
  • #6 16269150
    Ludwik XVI
    Help: 1325
    Rate: 788
    The problem is more complex than what Locoloco writes.
    There are actually 3 aspects:
    1. Given signal. In fact, movies are still shot at 23.97 fps. It doesn't matter what you watch. Whether 50 or 100 or 200 Hz. The movie will look the same unless you edit it on TV, which brings us to the next point ...
    2. TV image processor. Its task is to flow the given signal above the level in which it was recorded. Here, of course, a lamp lights up for cinephiles and picture purists. Each activation of such a function changes what the camera recorded, i.e. cheating starts ... the better the TV does it, the less the theater effect is (fatal, for example, on cheap TV, e.g. TCL)
    3. What was 100/120 / 200Hz for? Well, it appeared when 3D came in. Because here the matrix had to give / display 2 separate signals. The minimum without too much image flickering was done by the native 100Hz matrix.
    And thus we came to the point why in 2016 and 2017 there was a flood of 60Hz TV - the producers simply killed 3D technologies and hence the 100 Hz matrix was no longer necessary.
    They have stated the workhorse sales will now be 4K. So they raised the prices of their models, added nonsense 4K, cut 3D, lowered the matrix heres and ...... started making more money :)
  • #7 16269477
    jarrod
    Help: 59
    Rate: 131
    Ludwik XVI wrote:
    they added nonsense 4K, cut 3D, lowered the matrix heres and ...... started making more money :)
    With this nonsense I cannot agree. I have a camera that records in 4K, some say that if you don't see the difference, it's not worth overpaying. But in this case, you can see the difference.
    Movies in 4K also have a place to get in, so I completely do not understand your hate.
    Back to the topic. This MVA matrix in the 50DXU701 will not haunt me at night? ;)
  • #8 16269548
    Ludwik XVI
    Help: 1325
    Rate: 788
    You can see the differences, but it all depends on the distance. I'm sitting over 3.5m from the 55-inch screen (B6J) and I can't see the difference then ...
    And if you will be persecuted, I do not know ... I dream of more pleasant things than TV sets ;)
  • #9 16270556
  • #10 16272053
    jarrod
    Help: 59
    Rate: 131
    LOCOLOCO wrote:
    There are people who don't make a difference, and maybe you're in this group. It's nothing wrong.
    Will you write something in the subject? Which TV will you recommend?
  • #11 16274764
The discussion centers on comparing two Panasonic TV models: the TX-49DX600E and the TX-50DXU701, particularly focusing on their matrix types, HDMI and USB port availability, and suitability for a 20m2 room. The TX-50DXU701 is favored for its additional HDMI and USB ports and MVA matrix, while the TX-49DX600E features an IPS matrix. Users express concerns about the impact of matrix types on viewing experience, especially regarding motion clarity and color accuracy. The conversation also touches on the importance of the TV's image processor and the relevance of refresh rates, with some participants advocating for 100Hz models for better performance. Recommendations for other models in the same price range are provided, including options from Sony, Philips, TCL, and LG.
