Citroen DS4 2.0 HDI error P2084 - engine fault indicator appears
Rewel 19557 4
  • #1 16267468
    Rewel
    Hello, the error code as in the subject of the car is new, so no one was burying the mileage of 48 thousand. error P2084 appears after approx. 8-9 km from commissioning. After deleting for the first time it was a month good now the code returns every day I checked the connections to the sensor the cable is not damaged or frayed. Is the EGT sensor replaceable? I noticed air bubbles yesterday behind the fuel filter after venting on the filter today I managed to drive 19 km and again a mistake. Or maybe a dirty filter and here you should look for the cause causes problems with exhaust fumes which is manifested in error?
  • #2 16268069
    marfur30
    Help: 138
    Rate: 386
    Hello, buddy, if you have such an opportunity, reconnect your computer and check which sensor reads the temperature.
  • #3 16268823
    bsv2001
    Help: 26
    Rate: 183
    usually EGT sensor to be replaced
  • #4 16292514
    szwagier81
    Help: 13
    Rate: 147
    If the error caught occasionally I wouldn't care too much. doesn't it light up sometimes when it's wet? Maybe moisture on the cables has some influence? I would still twist this sensor and see if there is any residue on it
  • #5 16305298
    Rewel
    The sensor, however, to replace the wiring was OK. Thank you for your help.
