Citroen C4 1.6HDI DV6C - Measurement of the position of the EGR exchanger by-pas
pisior1987 22563 3
  • #1 17369897
    pisior1987
    Help: 12
    Rate: 351
    Car as in the topic, 2012, 115 HP, error P11B2
    The car was purchased with this mistake (it was in the front after an accident):
    I looked for this sensor and found something like this:
    Can`t find a plug for it anywhere. The original installation remains as if it had not been touched. Are there versions with and without a sensor? Maybe someone has a diagram?
  • #2 17371414
    pisior1987
    Help: 12
    Rate: 351
    Specifically, I`m talking about sensor no. 12. Because that`s probably what I`m talking about. This sensor appears by the chassis number. Unfortunately, I cannot locate it in the diagram:
    I am also sending the diagram:
    c4 1.6 hdI...ILNIKA.pdf (1.08 MB)You must be logged in to download this attachment.
    The diagram shows the EGR magnetic valve of the exhaust gas cooler flap, but I don`t see the flap sensor.
  • #3 20997528
    faye1364
    I am also looking for what is this sensor is. It's No 12 in the diagram?
  • #4 21102352
    autoserwisluxus
    Has anyone solved this?
    Same example: no plug and no light on the meter, but the error is there when connected.
