Whirlpool AWE F05 Washing Machine: Resolving 3 LED Error Code after Error F05 Fix
gubster 11427 6
  • #1 16269677
    gubster
    Rate: 10
    Hello, I recently had an error in my Whirpool F05 washing machine, but I dealt with it. She washed me 2 washes normally and after 3 washes the service turned on and these 3 diodes. I can't delete it at all or find the code for this error. I disconnected it for a few hours and set the program to 0, but it still lights up again. Please help.
    olekt2002
    Level 32  
    Help: 147
    Rate: 515
    Error F 05 is a problem with the NTC detector, examine it carefully and its wiring. By the way, check the heater resistance and its leakage to ground.
  • #3 16269723
    gubster
    Rate: 10
    I solved the error f05 because I found it to be a sensor but I have a problem now with this error what is in the picture because I can not find the code for this error and what it can be and how to "reset" the washing machine to turn off the service.
    tod.1977
    Help: 65
    Rate: 149
    If you have dealt with the NTC sensor, check the hydrostat and the heater. What happens to the washing machine before it displays the error?
  • #5 16269764
    gubster
    Rate: 10
    Thanks for checking for sure. And what happened to her? she was washing normally until at some point I just jumped the error closer I can't describe it because I just wasn't in the bathroom at the time.
  • #6 16269777
    tod.1977
    Help: 65
    Rate: 149
    Now what are the symptoms?
    Locking the flap? Pours water? The engine starts? Can't it be turned on at all?
  • #7 16269916
    gubster
    Rate: 10
    So far I have returned to the topic of f05 as you wrote and it has helped to clean the sensor and so far the washing works but I will let you know if everything will be ok. Thank you for your help at the moment.
The discussion revolves around a Whirlpool AWE washing machine displaying a service error indicated by three LEDs after initially resolving an F05 error related to the NTC sensor. The user successfully addressed the F05 issue but encountered a new error that could not be identified. Responses suggest checking the hydrostat and heater, as well as cleaning the NTC sensor. The user reported that cleaning the sensor resolved the F05 error, and the washing machine was functioning normally afterward.
