Whirlpool AWE7519 Washing Machine - Troubleshooting Error F08 Despite Replacing Burnt Cables
marek mezynski 7515 4
  • #1 16387956
    marek mezynski
    Rate: 11
    Hello, after switching on the washing machine you can hear a few cycles turn on and off and the code F08 is displayed. I have already read that it is about a heater, but the cables that enter the programmer were burnt on the terminals. I cut the tips and bound new ones. I crossed the cables with an ohmmeter and it showed 24.3? so it looks like the heater is good. Where should I look for the cause of the failure?
    I have corrected TONI_2003
  • #2 16388039
    Bridgestone
    Help: 30
    Rate: 105
    The heater may have fluidity by mass and it cannot be assumed that it is functional but you need to check it.
    If there were burned wires supplying the heater, one should also take into account the failure of the relay switching on the heater and this should also be verified.
  • #3 16417226
    marek mezynski
    Rate: 11
    Hello, I have not solved the problem yet because I did not have time to look into the device, but if I get over some important matters I will let you know. Thank you for the hint.
  • #4 16459683
    marek mezynski
    Rate: 11
    Hello after a long absence, but finally I found some time and replaced the heater. It was out of order, after replacement I started the washing machine and the code F08 was still displayed. So I thought about the relay and looked for a further reason. I removed the controller and after a long inspection came to a break between the pin from the heater and the pin from the hydrostat. I made a bridge and after restarting the washing machine the code F23 was displayed. I checked the patency of the hydrostat hose and pump, it's ok. Now I don't know what else to touch.
    I am asking for help and Thank you.
  • #5 16466220
    marek mezynski
    Rate: 11
    Hello, I solved the problem I was struggling with, namely the heater was damaged and shorted, as a result the burned path bridging the pins from the heater and hydrostat. The programmer was blocked by fault errors. I have reset the programmer and it's ok. Thank you for the hint.
