[Solved] Troubleshooting Whirlpool AWO / C 61010 Washing Machine: Heater Check for F08 Error
Python013 17022 11
How can I test the heater in a Whirlpool AWO/C 61010 washing machine for an F08 error, and what should I check if the heater is OK?
Test the heater first by disconnecting its power cables, then measure resistance across the two heater terminals and check for a breakdown from each terminal to the heater casing [#16975350][#16975590] A multimeter can verify the heater winding resistance, but it is not always reliable for detecting insulation breakdown; an insulation resistance meter is better for that test [#16978339] If the heater is fine, check whether voltage reaches the heater and inspect the control module [#16977637] The relay on the module is a likely fault, and it should be checked or replaced, especially the HF115F 012-1H3A/012-1H3AF relay [#16978208][#16979055][#16979152] In the thread, replacing the shorted HF115F relay and resetting the programmer fixed the washer [#16982042]
  • #1 16975143
    Python013
    Rate: 18
    I saw that the subject of error F08 in the Whirlpool AWO / C 61010 was rolled several times, but I need information from another side. ;)
    Namely, I am interested in how I can check the heater itself or have it actually retired?
    I have a multimeter and some tools, but I do not have knowledge about it.
    If the heater turns out to be efficient, what else can I check myself?
    Chupacabra
    Help: 247
    Rate: 868
    Python013 wrote:
    (...) the topic has already been rolled several times (...) how can I check the heater itself or have it actually retired?
    This topic has also been repeatedly rolled up. Make measurements with a meter with unfastened power cables. Resistance of the heater and puncture.
  • #4 16976661
    Python013
    Rate: 18
    The breaks did not show, and between the contacts came the value of 26.1?.
  • #5 16977637
    Chupacabra
    Help: 247
    Rate: 868
    Not always, the measurement of break through to mass is reliable. Now whether there is any tension on the heater. If not this photo of the module.
    falo22
    Help: 89
    Rate: 649
    If the heater is ok, the relay on the module will be replaced.
  • #7 16978248
    Chupacabra
    Help: 247
    Rate: 868
    To find out, you should do a simple measurement first.
  • #8 16978339
    bubu64
    Help: 57
    Rate: 283
    Losing time, or how your colleagues call it a "puncture", should be measured with an insulation resistance meter, not a multimeter :)
  • Sooty L003 area on control board inspected
    #9 16978926
    Python013
    Rate: 18
    I got the plate.
    Position L003 was some kind of sooty and has a strange impression as if it was in the water, but the elements are clean. I wanted to buy a repair kit for this tile on Allegro, but the seller did not advise me because in the case of the F08 he would not change anything.
    Troubleshooting Whirlpool AWO / C 61010 Washing Machine: Heater Check for F08 Error Troubleshooting Whirlpool AWO / C 61010 Washing Machine: Heater Check for F08 Error
    Chupacabra
    Help: 247
    Rate: 868
    Relay to be checked and preferably to be replaced.
  • #11 16979152
    Python013
    Rate: 18
    And something more can be learned about this relay? I suppose it's the bright rectangle or the two bright squares under this radiators? This rectangular relay has markings HF115F 012-1H3A and nowhere I can find it in stock. But I found HF115F 012-1H3AF, which differs in the additional letter at the end, and in the description everything is the same.
  • #12 16982042
    Python013
    Rate: 18
    Relay HF115F / 012-1H3AF I ordered yesterday afternoon, and today at 9:40 it was at my place. A moment of work with the exchange and resetting of the programmer and the washing machine whisks :)
    The relay was shorted.
The discussion revolves around troubleshooting the F08 error in the Whirlpool AWO / C 61010 washing machine, specifically focusing on checking the heater. Users suggest using a multimeter to measure the heater's resistance and check for breakdowns between the contacts and the heater casing. If the heater is functioning correctly, attention should shift to the relay on the control module, which may need replacement. One user successfully replaced a faulty relay (HF115F / 012-1H3AF), resolving the issue. Additional measurements, such as insulation resistance, are recommended for thorough diagnostics.
TL;DR: One relay replacement fixed the Whirlpool AWO/C 61010 F08 fault; “The relay was shorted.” Delivery-to-fix took a day. [Elektroda, Python013, post #16982042]
Why it matters: This FAQ helps DIYers quickly diagnose F08 heater-circuit faults and decide when to replace the control-board relay.
What does error F08 mean on a Whirlpool AWO/C 61010?
In this thread, F08 pointed to a heater-circuit problem. Users verified the element, then focused on the control-board relay. Replacing the relay cleared F08 and restored heating. Treat F08 as a heater path issue: element, wiring, or relay drive. [Elektroda, falo22, post #16978208]
How do I check the heater with a multimeter?
First, test resistance between the two working heater terminals with an ohmmeter. Then, in the meter’s highest range, check for any continuity between either working terminal and the heater casing. Any breakdown indicates a faulty element. If you feel unsure, ask for help. [Elektroda, Anonymous, post #16975590]
Do I need to disconnect wires before measuring the heater?
Yes. “Make measurements with a meter with unfastened power cables.” Measure the element’s resistance and check for insulation puncture to ground. This avoids parallel paths that skew readings and keeps you safe while testing. [Elektroda, Chupacabra, post #16975350]
What resistance should I expect across the heater?
Expect a finite resistance, not open or short. In this case study, a working element read 26.1 Ω across its contacts. Use this as a ballpark check; large deviations suggest issues with the element or wiring. [Elektroda, Python013, post #16976661]
Is a multimeter enough to catch insulation leakage to chassis?
Not always. A standard multimeter may miss marginal insulation faults. Use an insulation resistance meter (megohmmeter) for a proper leakage test between terminals and the heater casing. That tool stresses the insulation to reveal breakdowns. [Elektroda, bubu64, post #16978339]
My leakage test looks fine, but F08 persists—what next?
A clean multimeter test can still miss a fault. Verify whether the control module actually sends voltage to the heater. If not, inspect the board and focus on the heater relay and its drive. Photos help diagnosis. [Elektroda, Chupacabra, post #16977637]
Which relay controls the heater, and what’s the part marking?
On the control board, the heater relay in this case was marked HF115F 012-1H3A; another available marking was HF115F 012-1H3AF. These are the rectangular components near the heatsinked area on the module. [Elektroda, Python013, post #16979152]
Can I use HF115F 012-1H3AF in place of HF115F 012-1H3A?
Yes. The thread author sourced HF115F 012-1H3AF, installed it, reset the programmer, and the washer worked. This substitution resolved F08 because the original relay had shorted contacts. “The relay was shorted.” [Elektroda, Python013, post #16982042]
How do I perform a quick 3‑step heater test?
  1. Unplug the washer and disconnect heater power leads.
  2. Measure resistance between the two heater terminals.
  3. On the highest range, check between each terminal and the heater casing for breakdown. If leakage appears, replace the element. [Elektroda, Anonymous, post #16975590]
What’s a relay in this context?
It’s the control-board switch that applies mains power to the heater. If the element tests good yet F08 remains, the relay can be the culprit. Technicians in the thread recommend checking or replacing it when heater checks pass. [Elektroda, Chupacabra, post #16979055]
How long does the relay fix take, realistically?
In this case, the replacement relay arrived the next morning. After a brief soldering session and a programmer reset, the washer ran normally. This shows the repair can be quick once the part is in hand. [Elektroda, Python013, post #16982042]
What if I’m not confident using meters or soldering?
Do the visual checks, then stop. As one helper put it, if insulation testing or board work exceeds your comfort, ask someone experienced for help to protect you and the machine. [Elektroda, Anonymous, post #16975590]
My module shows soot near L003—does that confirm the fault?
Discoloration hints at heat or contamination, but it’s not conclusive. Proceed to electrical checks. Verify heater readings and whether the relay switches power before deciding on board repair. Share module photos if seeking advice. [Elektroda, Python013, post #16978926]
Why did my F08 clear after replacing only one component?
Because the heater relay had shorted contacts, preventing proper switching. Replacing that single relay restored control of the heater circuit and cleared F08 after a reset. One component change solved the fault in this thread. [Elektroda, Python013, post #16982042]
