Golf IV 1.6 16V petrol - Ignition failure from the cylinder 2
Sylwia45 21642 8
  • #1 16270952
    Sylwia45
    Candles were replaced in November. Four days later, the check lamp went on (the car weakened). After connecting to the computer, an error occurred - the ignition failure from the cylinder 2.
    From that moment, every two weeks, I repeat the mistake and my visit to mechanics and electricians.
    checked:
    * Coils and injections were swapped in places (one coil was replaced with a new one - 2)
    * pressure on cylinders: 1C- 16,5, 2C-15,5, 3C-16,5, 4-16.5
    * cabling (reportedly tested)
    * replaced oil
    The mechanics send me to the electricians while you send me to the mechanics.
    Please help
    with Respect "Desperate"
  • #2 16271127
    any56
    Help: 656
    Rate: 838
    Or maybe a candle?
  • #3 16271311
    Sylwia45
    All candles have been replaced. Why is it only for 2?
  • #5 16271411
    mario 77
    Help: 66
    Rate: 335
    For example, because one candle fell out of a box or a salesman in a store or simply sell.
    Sylwia45 wrote:
    checked:
    * replaced oil
    It would be worth making sure and at least translate this candle into a different cylinder.
  • #6 16271438
    grala1
    VAG group specialist
    Help: 1495
    Rate: 5049
    The car weakens only when the indicator appears, is it weak all the time?
    Is it possible to see the ignition out all the time or does it only show up by lighting up the lamp and weakening the car every 2 weeks?
  • #7 16272927
    Sylwia45
    The car weakens only when the control light appears, at this moment I hear and feel that the car is driving on three cylinders.
    Recently I traveled 200 km once and nothing happened. The next day I drove 2 km and the problem appeared again.
    I waited about 1 h and went to the mechanic (he was already on 4 cylinders).
    [/ Quote]
    It would be worth making sure and at least translate this candle to another cylinder. [/ Quote]
    the candles were put out of the cylinders and the same problem is still there.
  • #8 16272951
    Pedros050
    Help: 2471
    Rate: 3918
    @ Sylwia45 Hello. And has anyone checked whether the plug on the injector is well-established or are there no torn cables?
    Moderated By Pawel wawa:
    Warning, the post is correctly reported. Another, written by Coliseum, writing advice not supported by knowledge. If there really was such a simple problem, the controller would write an error regarding the damaged injector circuit. 3.1.11. Do not send messages that do not contribute to the discussion. They are misleading, they are dangerous or they do not solve the user's problem.
  • #9 16279008
    Sylwia45
    A few days a car was found in the electrician, the whole electrician and wiring was to be checked. The electrician replaced the coil and it was supposed to be good. I think this plug and cables are good.
✨ The discussion revolves around a persistent ignition failure in a Golf IV 1.6 16V petrol vehicle, specifically related to cylinder 2. The owner reports that after replacing the spark plugs, the check engine light illuminated, indicating an ignition issue. Despite multiple visits to mechanics and electricians, the problem recurs every two weeks. Various checks have been performed, including swapping coils and injectors, testing cylinder pressure, and inspecting wiring. Suggestions from the forum include verifying the spark plug installation, checking for leaks, and ensuring proper connections to the injector. The owner confirms that the electrical system was checked, and a coil was replaced, but the issue persists.
