VW Golf IV 1.6 16V: Flashing Check, Power Loss, Ignition & Injection Control Errors
Bullseye 10974 2
  • Suspect exhaust leak causing limp mode and misfire codes
    #1 16796628
    Bullseye
    Help: 55
    Rate: 89
    recently in golf my elastic connector broke and the car began to flash check and jerk which is obvious. I gave up to exhale, now it is all working, I deleted errors but after 2 minutes it started to jerk again, lose ignition, lack of power etc .....
    Spits out errors:
    16688 - cylinder 4 falling out of ignition
    17582 - Bank 1, deviation in injection control
    17526 - Bank 1, probe 2, open heating circuit
    17513 - Bank 1, probe 2, short to heating plus
    Damaged second probe (it is possible that damage to the second probe will trigger the emergency mode in the engine and they showed errors with the ignition falling out?)? Maybe they leaked the catalyst? Anyone advise?
  • #2 16797511
    mercedesik
    Help: 80
    Rate: 522
    I would start with the ignition loss, compression coil candle. Then probes etc.
  • #3 16797594
    moto-kord
    Help: 137
    Rate: 505
    Regarding the first error to be checked
    16688-Misfire in cylinder 4 has been detected
    1 Hall / MRE sensor on the camshaft
    2 Magnetic drive on a crankshaft
    3 Injector 4
    4 Ignition module
    17582-Circuit controlling injection time setting / open
    1 Injector 1
    2 Injector 2
    3 Injector 3
    4 Injector 4
    5 Hall / MRE sensor on the camshaft
    6 Magnetic drive on a crankshaft
