Guidance on Astra G Z18XE Simtec 71 ECU Replacement & P0130 Error Resolution
GuRaL1935 6087 3
  • #1 16271901
    GuRaL1935
    Hello, for some time I have the error P0130 - O2 sensor open circuit 1. Most likely it is a driver. I plan to buy a second one, but I have already read so much that I am lost, as well as other sentences. I will add that I have an op-com
    I have a driver:
    GM 55 351 751
    S 03 006 03
    5WK9 1726
    and hence some questions:
    1. What should I look for this driver if I could not find the same number? (Some write that it should be the same, others that only simtec 71, no matter the number)
    2. If I buy a driver with an immo loop and a stone, all I need to do is install and finito? (Recently a guest from the alledrogo offer told me that he also needed a counter / clocks that he has included, otherwise he will not program it)
    3. If I buy the driver only but logged out, it is enough to connect and program it with op-com?
    4. Programming is done by entering the immobilizer options, after entering the pin, and there was something to choose from. Installing immo and driver?
    5. How to log out the driver, I can't find it anywhere on the Internet, just after entering the pin, click ECU reset?
    Someone else wrote to me that you need to upload a new SPS and only TECH 2.
    Someone also hinted at me to try to add extra weight to the probe. How to do it?
  • #2 16271955
    piotrekwoj1
    Help: 943
    Rate: 3416
    You have a working probe, what is the heater resistance, the voltage reaches the probe? The beam is checked, but not with a meter but a light bulb?
  • #3 16272617
    GuRaL1935
    The probe, first I mounted a stimulant and for a while after installing it, when it was warming up, it started to show something there, and then it stood at 412mV, I finally bought VDO and the same.
    I checked with the meter the beam from the pins in the cube at the controller to the pins in the cube for the probe, like the meter was squeaking.
    I did something like in the attachment.
    I still have a video of checking the gray and black wires https://www.youtube.com/watch?v=ZcC8re9fzAA
    Possibly the topic that I set up to reach whether it is a driver or a probe https://www.elektroda.pl/rtvforum/topic3186837.html
    • sonda.docx (3.29 KB) You must be logged in to download this attachment.
  • #4 16274674
    marcinmisiek102
    Rate: 10
    reset in opcom is logging out
    immo opcom as much as possible
    new soft for the driver only tech, but if it was operational, it will work
