Astra H 2006 1.9DT - ECU Replacement & CIM Reset: Old Key Coding & Immo Code Changes
piotrekwoj1 7506 14
Can I recode the original Astra H keys after replacing/resetting the ECU and CIM, or do I need new transponders?
Yes—the thread ends with the conclusion that the original keys can be recoded back to the car they came from, and it was done with OP-COM [#16341387][#16342055] Several replies warn that if the CIM/ECU programming went wrong or the key transponder is from another car, you may not be able to add the old keys back and may need new or clean crypto transponders instead [#16336020][#16336937][#16338641] The transponder mentioned for Astra H is PCF7941AT, and one reply says the key type matters when deciding whether it can be reused [#16336131]
  • #1 16335943
    piotrekwoj1
    Help: 943
    Rate: 3416
    Hello in the car, the engine controller was replaced because the old one was damaged and a certain spec reset both the ecu and cim, then the keys were thrown away and a problem arose because the old keys cannot be coded. Is it possible to remove the mechanical key from the controller's memory? because I don't know what's in it. On 99% of the cim it has a programmed key number from the new ecu and therefore I will not add the old keys because the immo code has changed.
  • #2 16336020
    tomek4
    Help: 57
    Rate: 100
    Hello in astra h, you will not write back old keys, you need to replace the crypto
  • #3 16336062
    piotrekwoj1
    Help: 943
    Rate: 3416
    You are sure, it seems to me that if I had the correct mechanical key, the old keys will be added. I'm 90% sure I've already done that.
  • #4 16336131
    tomek4
    Help: 57
    Rate: 100
    There is a PCF7941AT transponder
  • #5 16336147
    piotrekwoj1
    Help: 943
    Rate: 3416
    Hello again, according to the directory
    http://transpondery.com/transponder_catalog/opel_transponder_catalog.html
    the same transponder is in the vectra, there you can 100% re-code the key from this car. Maybe we did not understand each other, I do not want to add a stimulant from another car, only the original key from this car.
  • #6 16336190
    tomek4
    Help: 57
    Rate: 100
    Okay, but when you write that you replaced, you reset the ecu and cim, is it not like it was from another car
  • #7 16336277
    piotrekwoj1
    Help: 943
    Rate: 3416
    It's not me, but ok. Just that the immo key is generated on the basis of a mechanical key that is 100% saved in cim and I do not know if it is also in ecu because if it was, I have the old ecu and bin from it. I connect the old ecu and cim "gets the key from the old ecu" then I have the opportunity to view it and upload it to the cim and add the old keys. Only the old ECU is damaged and the memory transfer or key reading from the file remains. I am not 100% sure if it will work. Cim can be logged in from another car, provided that you have a pin and a mechanical key and the keys can then be added again.
  • #8 16336314
    janusz2008
    Help: 170
    Rate: 515
    Interesting?. keys erased from immo with transponder cr. you will not write with the cable.
  • #9 16336347
    piotrekwoj1
    Help: 943
    Rate: 3416
    So there are new transponders or a key reset.
  • #10 16336937
    wolf16
    Help: 32
    Rate: 115
    vectra c has pcf 7946 and this is a completely different key if something went wrong during the CIM programming procedure, there is no option to add old keys.
    klucze.sosnowiec.pl
    Długosza, Sosnowiec, 41-219 | Company Website: https://klucze.sosnowiec.pl
  • #11 16338070
    piotrekwoj1
    Help: 943
    Rate: 3416
    It seems to me that I will add but new or cleaned.
    Will anyone explain why the keys with the transponder 7946
    will add again and 7941 not? The layout application is identical.
  • #12 16338641
    janusz2008
    Help: 170
    Rate: 515
    New for sure. 7946 are spare, you will also write clean. New, around PLN 30 is it worth it?
  • #13 16341387
    piotrekwoj1
    Help: 943
    Rate: 3416
    Hello, the problem is over again, and I was right, the keys can be re-coded to the car they came from. Thanks for the hints.
  • #15 16342055
    piotrekwoj1
    Help: 943
    Rate: 3416
    Op-com did it.
✨ The discussion revolves around the challenges faced after replacing the ECU in a 2006 Astra H 1.9DT, particularly regarding key coding and immobilizer (immo) code changes. The user inquires about the possibility of removing the old mechanical key from the ECU's memory after the keys were discarded. Responses indicate that the old keys cannot be re-coded due to the new ECU and CIM (Column Integrated Module) setup, which requires a new crypto key. The PCF7941AT transponder is mentioned, with references to its compatibility with other models like the Vectra. It is noted that while the keys can be re-coded to the original vehicle, issues may arise if the CIM programming was incorrect. The discussion concludes with confirmation that new or cleaned transponders can be used for key re-coding.
