If it is not possible by logging in, it means damage, repair of which requires service, or maybe even replacement of some part. It only gets into the file system, if not a damaged disk, by shifting to another device.
The discussion revolves around issues with the Lenovo B50, specifically the non-functional recovery button and difficulties logging into Windows 10. Users suggest checking if the hardware is under warranty, as repairs may be necessary. If the recovery option is unavailable, one potential solution is to use a Windows 10 installation disc to restore the system. There are concerns about possible hardware damage if login attempts fail, indicating the need for service or part replacement. AI summary based on the discussion. May contain errors.
