Lenovo G50-30: BIOS Access & Reset Issues - Nova Button Not Responding, Key Combinations
Orzeszkowe 56418 12
How do I enter the BIOS on a Lenovo G50-30 if the Novo button does not respond?
On the Lenovo G50-30, the BIOS is normally entered by pressing the small Novo button next to the power socket while the laptop is switched off [#17004999] If that does not work, try starting the machine with Fn+F2, which is listed for this model in several descriptions [#17004967] Another suggestion is to connect a USB keyboard and hold F2 or Delete during startup [#17006831]
  • #1 17004915
    Orzeszkowe
    Rate: 11
    Hello. I am trying to launch the BIOS because I have to reset the settings, but the Lenovo Nova button (the one that is next to the power input) does not respond. Is there any special key combination for this model, because I've tried everything and nothing?
  • #2 17004961
    Pedros050
    Help: 2471
    Rate: 3927
    Hello. On the off laptop we keep the Nova button and enter the BIOS. How do you not enter something with him wrong?
  • #4 17004999
    dzg4
    Help: 132
    Rate: 364
    Hello, there is a button with a diameter of about 5 mm at the power socket, on the off laptop press it and you have access to the bios. I will replace that it works on my and my friends' laptops G50-30.
  • #5 17005838
    Orzeszkowe
    Rate: 11
    Unfortunately, no way works
  • #6 17005853
    Pedros050
    Help: 2471
    Rate: 3927
    Show the housing with the keyboard of this laptop? Or an evil model of this Lenovo?
  • #7 17005857
    Orzeszkowe
    Rate: 11
    The power button has nothing, it is a power wheel but I repeat that it does not react at all with this button or any key combination
  • #8 17005873
    Pedros050
    Help: 2471
    Rate: 3927
    Is not sometimes pressed inside and does not touch anything? How do you press a click?
  • #9 17006806
    Orzeszkowe
    Rate: 11
    Yes, it's not pressed
  • #10 17006814
    Pedros050
    Help: 2471
    Rate: 3927
    It's okay now on off, press the one on the side of the Novo button. And if it does not help, try on the sleeping system? Or do it without a disk.
  • #12 17006834
    Pedros050
    Help: 2471
    Rate: 3927
    I will give you instructions to him. lenovo_g_z...polish.pdf (5.84 MB)You must be logged in to download this attachment.
  • #13 17009806
    Orzeszkowe
    Rate: 11
    Thanks to everyone, I gave it to the site and it turned out that the disc had been closed
The discussion revolves around accessing the BIOS on the Lenovo G50-30 laptop, specifically addressing issues with the Nova button not responding. Users suggest pressing the Nova button while the laptop is off to access the BIOS, and mention the key combination of Fn + F2 as a potential alternative. However, the original poster reports that none of these methods work, indicating that the Nova button may be malfunctioning. Additional suggestions include using an external USB keyboard to press F2 or Delete, and checking if the Nova button is physically stuck. Ultimately, the original poster resolves the issue by discovering that the disk had been closed, which was preventing access.
TL;DR: On the Lenovo G50-30, a ~5 mm "Novo" button by the power jack opens BIOS; “press it and you have access to the bios.” [Elektroda, dzg4, post #17004999]
Why it matters: This FAQ helps G50-30 owners fix unresponsive Novo buttons and still reach BIOS to reset settings or boot order.
How do I enter the BIOS on a Lenovo G50-30?
Power off the laptop. Press the side Novo button to open the Novo Menu. Choose BIOS Setup from the list. If the screen stays black, try again with the charger connected. “On the off laptop we keep the Nova button and enter the BIOS.” [Elektroda, Pedros050, post #17004961]
Where is the Novo button on the G50-30 and what does it look like?
It sits next to the power socket. It’s a small round button, about 5 mm in diameter. Press it only when the laptop is completely off to trigger the Novo Menu and reach BIOS Setup. “Press it and you have access to the bios.” [Elektroda, dzg4, post #17004999]
What key combination opens BIOS if the Novo button doesn’t work?
Hold Fn+F2 while turning the laptop on. Start pressing before you hit the power button and keep holding until BIOS appears. One post notes this combo “appears in many descriptions” for G50 models, which includes the G50-30. [Elektroda, krzysiek_krm, post #17004967]
Can I use an external keyboard to get into BIOS?
Yes. Connect a USB keyboard, then hold F2 or Delete during power-on. This bypasses issues with a worn internal keyboard. Users report success using this approach on the G50-30. “Connect the keyboard to USB and normally hold the F2 / Delete key.” [Elektroda, RafalB, post #17006831]
My Novo button does nothing—what should I check first?
Verify the laptop is fully powered off. Press the Novo button and feel for a distinct click. If there’s no click, the button may be stuck or not contacting internally. Try again with AC power connected. If still dead, move to keyboard methods. [Elektroda, Pedros050, post #17005873]
Why can’t I get into BIOS even after trying all keys and Novo?
A storage fault can mask prompts or stall startup. In the thread case, service found the disk was “closed,” and normal access resumed after fixing the drive issue. If inputs seem ignored, diagnose storage next. This is an edge-case but real. [Elektroda, Orzeszkowe, post #17009806]
What exactly is the Lenovo Novo button?
It’s Lenovo’s dedicated recovery button that, when pressed on a powered-off machine, opens the Novo Menu. From there you can choose BIOS Setup, Boot Menu, or Recovery. On G50-30 it’s a small 5 mm button near the power jack. [Elektroda, dzg4, post #17004999]
How do I reset BIOS settings on a G50-30?
Enter BIOS using the Novo button or Fn+F2. In BIOS, choose Load Setup Defaults, then Save and Exit. If you can’t enter BIOS due to an unresponsive button, use the USB keyboard F2/Delete method first. [Elektroda, RafalB, post #17006831]
Does the exact Lenovo model variant matter for BIOS entry steps?
Yes, confirm the precise model and keyboard layout. A responder asked to verify the housing and model, implying variations. If your layout differs, prioritize the USB keyboard method to eliminate key-scan quirks. [Elektroda, Pedros050, post #17005853]
How can I tell if the Novo button is physically stuck?
Press gently and listen or feel for a click. If it feels mushy or doesn’t click, it may not contact the switch beneath. In that case, skip to keyboard entry or consider hardware inspection. “Is not sometimes pressed inside and does not touch anything?” [Elektroda, Pedros050, post #17005873]
Step-by-step: enter BIOS with the Novo button
  1. Shut down the laptop completely.
  2. Press the side Novo button once and wait for the Novo Menu.
  3. Select BIOS Setup and press Enter. “On the off laptop we keep the Nova button and enter the BIOS.” [Elektroda, Pedros050, post #17004961]
Is Fn+F2 always required on the G50-30?
Not always. Some units accept F2 alone; others need Fn+F2, per user reports. Start with Fn+F2 if your F-keys default to media actions. This combination is cited for G50-series BIOS access. [Elektroda, krzysiek_krm, post #17004967]
Could a bad hard drive prevent BIOS from showing?
BIOS should show regardless, but a failing drive can hang the splash screen or hide prompts. In this thread, service fixed access after addressing a “closed” disk. If keys fail and Novo is dead, check the drive early. [Elektroda, Orzeszkowe, post #17009806]
What’s the fastest fallback if the internal keyboard is unreliable?
Use a wired USB keyboard and hold F2 or Delete during power-on. This method removes any doubt about internal keyboard faults and often works immediately. It’s the quickest practical workaround. [Elektroda, RafalB, post #17006831]
Any simple statistic from this thread I should know?
One concrete detail: the Novo button on G50-30 is about 5 mm wide, which helps you locate and press the correct control quickly. That measurement guided the successful BIOS entry reports. [Elektroda, dzg4, post #17004999]
