Seeking Recommendations for Volvo V70 2.4D5 (2006) Diagnostic Cable - Webasto Compatible
28074 14
What diagnostic cable/software should I buy for a 2006 Volvo V70 2.4D5 with DPF, and do I need a separate cable for the Webasto heater?
Buy VIDA/DICE for Volvo; for home use a Chinese clone is considered fine, and one reply says you can do everything in the car with VIDA, including checking parameters and individual modules [#16273372] [#16279230] One user also reported that a 2012A VIDA and older works with V70, while 2014D does not work with V70 after 2001 [#16617979] For the heater, the thread does not clearly recommend a separate cable; one reply says the parking heater/Webasto should also be covered by ELM, so no separate Volvo-specific cable was clearly identified for it [#16273358]
  • #1 16273342
  • #2 16273358
    szymitsu21
    Help: 343
    Rate: 1301
    something to reset errors, I think some ELM or something is enough.
    Webmasto should also embrace ELM.
    MobilTruck
    Help: 139
    Rate: 965
    Keywords are: Vida volvo
    szymitsu21
    Help: 343
    Rate: 1301
    Here you are already talking about high-level diagnostics.
  • #5 16273400
    MobilTruck
    Help: 139
    Rate: 965
    Judging by the subjects of the questioner, he shouldn't spoil anything in the car and the Chinese, as he wrote, will buy for funny money.
  • #6 16273402
  • #7 16273407
    MobilTruck
    Help: 139
    Rate: 965
    eurotips wrote:
    Where's the dog buried?
    In software.ELMem you will do more than just dedicated IDS in new Ford cars.
  • #8 16273438
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6433
    But about whether you write colleagues, V70 after lifcie diagnosis goes for CAN and either a professional tester for a few kPLN or company.
    After 12 what do you want to do there with this volvo?
    As for the parking heater because it is not webasto or ribs, then you have nothing to look for with a tester.
    And if it's not enough, there is nothing to look for.
  • #10 16273499
  • #11 16273522
    Help: 1405
    Rate: 6433
    Diagnosis and testers as above
  • #12 16279230
    sirtrojan
    Rate: 21
    Like volvo, it's just VIDA. It is not cheap but if you insist, you will buy PLN 500.
    In the car you will do everything, check every parameter and functioning of each individual module.
    So I have what I say :)
    Ew. make friends with someone who has such a computer. On volvoforum you will find someone in the area.
  • #13 16279974
  • #14 16279991
    Help: 1405
    Rate: 6433
    eurotips wrote:
    At first glance, these two quoted entries contradict each other,
    Why if you choose the Chinese it is a cheaper version.
  • 2012A Vida Dice needed for post-2001 V70
    #15 16617979
The discussion revolves around finding a diagnostic cable for a 2006 Volvo V70 2.4D5, specifically one that is compatible with Webasto heating systems. Users suggest that an ELM-based tool may suffice for basic error resetting, but caution that many ELM devices are designed primarily for gasoline engines, which may not work with the diesel engine in question. The recommended software for comprehensive diagnostics is VIDA Volvo, which allows for detailed vehicle parameter checks. Users also discuss the differences between various VIDA versions, noting that the 2012A version is preferable for the V70 model. The conversation highlights the importance of ensuring compatibility with the specific engine type and model year when purchasing diagnostic tools, especially from Chinese suppliers.
