ELM 327 Interface Not Connecting to Car: Damaged CD, Software/Driver Issues, Red Lamp & OBD2
marek517398 8730 10
Why won’t my ELM327 interface connect to my 2002 Volvo S60 2.4 petrol, even though the diagnostic software detects it?
Your Volvo S60 2.4 petrol from 2002 does not use ELM327/standard OBD2 software for full diagnostics; only VIDA with a DiCE interface connects to it [#16934056] Even if ELM327 manages to connect, it would be limited to the engine module and still not be very useful for other functions [#16934077] So the problem is most likely interface/software incompatibility with this car, not the damaged CD or the red lamp itself [#16934056][#16934077]
  • ELM327 connects to PC but not OBD2
    #1 16933895
    marek517398
    Hello. Not long ago I bought the ELM 327 diagnostic interface. Unfortunately, it came with a damaged CD with software and drivers for it. I searched and installed drivers and several diagnostic programs, unfortunately, still no reason because the interface does not connect to my car. After connecting the interface to the computer one red lamp lights up when connected to OBD2 nothing happens. Earlier I used the viaken interface and VAG software there, after connecting the interface to the OBD2 socket the green LED was on. Is something wrong with the ELM 327 interface? Has anyone used this amazing device? Please help and thank you in advance for your answers.
    Ps. the interface itself connects to the diagnostic program
  • #2 16933986
  • #3 16934017
    Krzys55
    Help: 89
    Rate: 303
    The car production year is important
    What program are you using?
  • #4 16934032
    marek517398
    Volvo S60 2.4 petrol 2002 SDPROG, SCAN MASTER, SCANTOOL.NET, OBDWIZ
  • #5 16934056
  • #6 16934062
    marek517398
    So there is no connection option via the ELM 327 interface?
  • #7 16934077
  • #8 16934105
    marek517398
    Not only Vida, because my friend hooked up with delphi software. I do not mean coding just about the airbag error cancellation is everything.
  • #9 16934166
  • #10 16934179
    kkknc
    Help: 1915
    Rate: 6705
    No problem ..... You just have to do a multiplexser and write your own software.
  • #11 16934227
    marek517398
    Ok thanks for the help in this case I give up attempts to connect quinoline only specific software remains.
The discussion revolves around issues faced by a user with an ELM 327 diagnostic interface that fails to connect to a 2002 Volvo S60 2.4 petrol vehicle. The user received a damaged CD containing necessary software and drivers, leading to unsuccessful attempts to establish a connection using various diagnostic programs, including SDPROG, SCAN MASTER, SCANTOOL.NET, and OBDWIZ. Responses highlight that the ELM 327 may not be compatible with the Volvo, as only specific software like VIDA or Delphi can connect to the vehicle. Users emphasize the importance of using the correct software for error clearing and suggest exploring local forums for VIDA connections. The conversation concludes with the user considering abandoning the ELM 327 in favor of more compatible options.
