Seeking Software and Drivers for LC 32LE144E TV Not Found on Manufacturer's Site
arkus.polska 5364 5
  • #1 16275408
    arkus.polska
    Rate: 15
    Hello. I am looking for software and drivers for this TV. They are not available on the manufacturer's website. Best regards.
  • #3 16276682
    arkus.polska
    Rate: 15
    Hello, unfortunately I can't download it because I don't have that many points. In the meantime, on a well-known auction site I found a programmed 25Q64 bone for PLN 10 and I'm going to buy and replace it. And by the way, it's a bit strange that there is no such software on the manufacturer's website. Regards
    remot
    Help: 278
    Rate: 220
    Try this bin. Without commission
    • xx_LEx44_111_REV00.bin (3.96 MB) You must be logged in to download this attachment.
  • Factory reset completed after full file update
    #6 19484410
    Marianoitaliano69
    Hello. I’ve had the same problem lately. For me, it was a bit different because after connecting the pen, I started to load it up to 20% and then I had a message to remove the pen and disconnect it from the network.
    And no improvement. Once every 10 times it turned on without scanning (after disconnecting from the power supply) and then I loaded the full file through the settings menu in Tv. The installation went to 100% and a message popped up saying that factory settings have been restored :) And the problem is over :) So many years and Tv still works :)
