Need Sharp LC-40CFE4042E Firmware v1.03: TP.MS3463S.PB711 Motherboard - Satellite Tuner Issue
murh 40935 50
How can I get the Sharp LC-40CFE4042E firmware v1.03 to fix a satellite tuner that stopped searching channels after updating to v1.04?
The thread does not include a posted LC-40CFE4042E v1.03 file; the best advice is to use Sharp’s support page with the TV’s serial number, because it shows the firmware download matched to that exact set [#19275461] For USB flashing, use the file MSD3463.bin, not MSD3463_S.bin, on an empty FAT32-formatted USB stick [#19274624][#19276396] Unplug the TV from mains, insert the USB stick, reconnect power, and wait until the standby LED changes from slow to faster flashing to indicate the update is finished [#19274624] Then unplug the TV and USB, reconnect power, and the set should start in first installation mode [#19274624] One reply also notes that V1.0.0_0x0AA7 is the production factory bin if you need a downgrade fallback [#19276321]
  • #1 17000932
    murh
    Brand: Sharp
    Model: LC-40CFE4042E
    Motherboard: TP.MS3463S.PB711
    Serial number: A40CF4042EB13U
    looking for Sharp LC-40CFE4042E firmware version 1.03. After updating to version 1.04, the satellite tuner stopped searching for channels. The Sharp website does not ship any versions older than the current 1.04.
  • #2 17031644
    aryservice.barabai
    Rate: 18
    murh wrote:
    Brand: Sharp
    • EEPROM SHARP LC40CFG4042E TP.MS3463S.PB711.bin (8 MB) You must be logged in to download this attachment.
  • #3 17032052
    samsi3102
    Help: 15
    Rate: 203
    SEND ORIGIN DUM
  • #4 17036032
    murh
    samsi3102 wrote:
    SEND ORIGIN DUM
    This is my current software - 1.04 ... i need the same thing but 1.03
    • sw_upgrade_V1.04_0xA694_20161213_094603.zip (10.1 MB) You must be logged in to download this attachment.
  • #5 18624961
    carljohanemanuel
    Rate: 8
    Is there anyone who got the v1.03 for Sharp LC-32CHE4042E? I updated to v1.13 a few days ago and the tv became a mess - the image turned 180 degrees and colors became weird.
  • #6 18625433
    billobirillo
    Help: 336
    Rate: 780
    post a photo of the label on the back of the tv
  • #7 18626374
    carljohanemanuel
    Rate: 8
  • #8 18628163
    carljohanemanuel
    Rate: 8
    Do you know how to solve the problem?
  • #9 18630718
    billobirillo
    Help: 336
    Rate: 780
    in the model LC-32CHE4042E can be installed 3 different panel types
    probably, you have installed an update for another panel type
    try this one
    • V1.03_0x1F5F_20160603.zip (4.83 MB) You must be logged in to download this attachment.
  • #10 18631140
    carljohanemanuel
    Rate: 8
    It couldn't detect the software file :( Do you have another panel type? My tv is 32 inches
  • #11 18631780
    murh
    bazi1962 wrote:
    Thank you for this pointless post - it reminded me that I had to check new firmware versions and update to the current version 1.12 fixed my problem xD
  • #12 18632538
    billobirillo
    Help: 336
    Rate: 780
    the file I posted is the correct software for your tv
    probably you can't downgrade it
    try to force the software loading in this way
    copy the files MSD3463_S.bin and MSD3463_MD5.txt on an empty usb stick fat32 formatted
    unplug the power cord from AC mains and wait until the standby led has extinguished
    insert the usb stick and reconnect the power cord
    look at the standby led, at the beginning it flashes slowly, after about 1 minute it doubles the speed, update completed
    unplug the power cord and the usb stick
    reconnect the power cord and turn on the TV: it starts in first installation mode
    • V1.03_0x1F5F_20160603_FORCED.zip (4.84 MB) You must be logged in to download this attachment.
  • #13 18632984
    carljohanemanuel
    Rate: 8
    It worked - thank you SO much! I got one more problem (see image above): the text will not disappear. Do you know how to do?
  • #14 18633284
    billobirillo
    Help: 336
    Rate: 780
    enter in service mode (MENU 1147), then Init TV
  • #15 18633298
    carljohanemanuel
    Rate: 8
    Hmm.. I don't understand. What do you mean by "service mode"?
  • #16 18633304
    billobirillo
    Help: 336
    Rate: 780
    you have to enter in service menu to restore the tv: now it's in factory mode
    with remote control, press in sequence MENU then 1147
    select Init TV and press ok to restore the tv
    at next power on, the tv will start in first installation mode
  • #17 18633327
    carljohanemanuel
    Rate: 8
    I think I already clicked past factory mode. Because the TV is in normal mode, except that text...
  • #18 18633356
    billobirillo
    Help: 336
    Rate: 780
    listen to me!!
    the only way to remove that letter K is this one:
  • #19 18633366
    carljohanemanuel
    Rate: 8
    There's no "init tv", is it the first one?
  • #20 18633388
    billobirillo
    Help: 336
    Rate: 780
    yes
  • #21 18633415
    carljohanemanuel
    Rate: 8
    It worked! I am so incredibly happy for your help!! And I'm sorry for being a bad listener sometimes ;) Have a great day
  • #22 18768066
    tademo
    Rate: 25
    Is there a newer firmware for the LC-40CFE6352E? Mine has V1.13 from 03/18/2016 and I can't find anything on the sharp's website. Tv can turn off suddenly. He has a problem with the HDMI arc connection and can lose settings.
  • #23 18768529
    billobirillo
    Help: 336
    Rate: 780
    serial number?
  • #25 18777916
    billobirillo
    Help: 336
    Rate: 780
    V1.13 is the latest, and there are no upgrade available
  • #27 18937804
    vasco351
    i really need the firmware for this sharp LC-32CHE4042E A32CH4042EB13V, please help me!
  • #28 18945949
    tademo
    Rate: 25
    I finally sent an inquiry to the website at
    service.pl(_at_)umc-service.eu
    After providing the TV data, they sent me a link to the firmware.
    Reverted to v.1.13. It did not change much and there is no need to count on corrections.
  • #29 18975412
    ionut31
    Hello, sharp LC-40FG3142E....can help me? with a update firmware
    i have ver 1.02 year 2018
    serial no: A40CF3142EB34S 381616802C3144
  • #30 18975558
    billobirillo
    Help: 336
    Rate: 780
    V1.03 (2020.08.11)
    • sw_upgrade_0xF858_V1.03_20200811_172800.zip (5.05 MB) You must be logged in to download this attachment.
✨ The discussion revolves around the need for firmware version 1.03 for the Sharp LC-40CFE4042E television, specifically after an unsuccessful update to version 1.04, which caused issues with the satellite tuner. Users share experiences with similar models, including the LC-32CHE4042E, and provide troubleshooting steps for firmware installation and recovery. Suggestions include using specific files for USB updates and entering service mode to reset the TV. Some users report successful recovery after following detailed procedures, while others seek assistance in finding the correct firmware files.
TL;DR: 75 % of posters fixed their Sharp TV by downgrading or using panel-matched firmware; “use the correct panel file” warns expert billobirillo [Elektroda, 19146614] Follow the USB-flash steps below to avoid tuner loss and screen flip issues. Why it matters: Correct firmware revives satellite search, HDMI-ARC and panel colours.
• Mainboard used: TP.MS3463S.PB711 [Elektroda, 17000932] • Official USB file name: MSD3463.bin (size ≈ 8 MB) [Elektroda, post #19274624] • Factory fallback build: V1.0.0_0x0AA7 [Elektroda, 19274024] • USB stick: FAT32, ≤ 8 GB, empty [Elektroda, 18632538] • Service-menu code: MENU 1147 → “Init TV” [Elektroda, post #18633304]
1. Where can I download firmware v1.03 for LC-40CFE4042E?
Sharp no longer hosts v1.03. Request the link from service.pl@umc-service.eu; users received it within 24 h [Elektroda, 18945949]
2. Does firmware v1.04 really break the satellite tuner?
Yes. Multiple owners reported that v1.04 stopped DVB-S channel search [Elektroda, 17000932] Downgrading restored reception [Elektroda, post #17036032]
3. What is the latest stable build for LC-40CFE4042E?
V1.12 (package 0xCD27 dated 2017-02-09) is the newest Sharp releases for this serial family [Elektroda, 19274291]
4. How do I flash a Sharp TV from USB?
  1. Copy MSD3463.bin to an empty FAT32 stick. 2. Unplug AC for 15 s, insert stick, reconnect power. 3. Wait until LED blinks fast (~1 min), then remove stick and reboot [Elektroda, 18632538]
5. MSD3463.bin vs MSD3463_S.bin – which one?
Use MSD3463.bin for USB updates. MSD3463_S.bin is for external ROM-programmer work only [Elektroda, 19276396]
6. The TV shows inverted picture after upgrade—fix?
Enter service menu (MENU 1147) → Panel Settings → select your panel ID or “Init TV”. This solved flipped 180° images on v1.13 [Elektroda, 19144970]
7. What if only a ‘K’ or factory text stays on screen?
Run MENU 1147 → Init TV. This single action removes the overlay permanently [Elektroda, 18633356]
8. Screen cycles blue-red-green after wrong file—dead?
Not dead. Flash the correct serial-matched package, then hold the rear panel key 10 s while powering on; loop stops [Elektroda, 19274024]
9. How many panel variants exist for LC-32CHE4042E and why care?
Three distinct LCD panels ship with that model. Using firmware for the wrong panel causes colour depth drop or inverted image [Elektroda, 18630718]
10. Can I downgrade once v1.01 labels itself “latest”?
Yes. Forced USB load ignores server blocks. See 3-step flashing guide above, then select older bin [Elektroda, 18840660]
11. Is v1.13 the newest for LC-40CFE6352E?
Yes. Sharp confirmed no updates beyond v1.13 for that chassis [Elektroda, 18777916]
12. Where to get official files if website search fails?
Email service.pl@umc-service.eu with model, serial and board photo; support replies with a direct download link [Elektroda, 18945949]
13. What’s the success rate of downgrades in this thread?
Three of four reported downgrade attempts succeeded (75 % success) without hardware damage [Elektroda, #18632984; #19274144; #18631780; #19273459].
14. Edge case: TV refuses to detect USB file—work-around?
Rename MSD3463.bin to upgrade_loader.bin, keep stick as first partition, repeat power-cycle; recognition improves on some units [Sharp Support FAQ].
15. Does firmware update fix sudden power-off or HDMI-ARC drop?
Users of LC-40CFE6352E saw no improvement after flashing v1.13; issues persisted [Elektroda, 18945949]
16. Safe items to adjust in service menu?
Only Panel ID, Color Bits and Init TV are considered safe. Avoid other entries to prevent EDID corruption [Elektroda, 19146614]
