Best Lens Options for Canon EOS 1300D Under PLN 1300 - Recommendations and Comparisons
cyctrus741 10155 9
Which lens should I buy for a Canon EOS 1300D with a budget of up to PLN 1300?
If you are starting out, buy the standard 18–55 mm lens; it is the safest choice for learning on the EOS 1300D and covers everyday use [#16279897][#16277386][#16277392] If you need more reach, the 55–250 mm is the telephoto option, but on APS-C it behaves like roughly 88–400 mm and is meant more for occasional use [#16277386] For family and landscape photos, the lens you already have is usually enough, and there is no magic glass that will automatically eliminate distortion or make images much sharper [#16280153] For night photos, a tripod matters more than a new lens, because sensible night exposures can run from about 1 second up to 30 seconds [#16280153] Several replies also recommend learning the camera first and taking many photos before spending money on a more expensive lens, so you can figure out what you really need [#16277392][#16280822]
  • #1 16277350
    cyctrus741
    Rate: 12
    Which lens should I buy for the EOS 1300D? I would like to fit up to PLN 1300, which one?
    link
    link
    link
    link
    link
  • #2 16277386
    scotch
    Help: 78
    Rate: 148
    Buddy, first question: what is it for? You've entered a focal length range of 18-55 mm and 55-250 mm. The first range is practically standard focal length in Cannon lenses sold in "store" sets. The second range is already a tel-lens. As the camera has an APS-C matrix, the focal length will be (i.e. what the matrix sees) 28-88 mm and 88-400 mm, respectively. As for the first range, you can still manage by taking pictures from the so-called "hand". to the second decent tripod. The second thing is what the lens is for. The first provides daily needs in 99%, the second is needed in sporadic cases, unless the colleague's needs are in the reverse order. Personally, I have a Cannon EOS 600D. To him, among others 200 mm fixed lens (i.e. 320 mm for Cannon) used very rarely.
    krzysztofh
    Help: 101
    Rate: 937
    Buddy, you're showing a set of completely different lenses. I have the impression that you want to buy anything. As a beginner photographer, I would advise you to take 30,000 photos with your Canon and then go shopping.
    Then you will know yourself what you want, because probably not yet.
    I advised you in another thread that you buy some books first, at least one Bryan Peterson, and it will certainly be a great investment in yourself.
    You will understand many things that you can't write about in a few words.
    You will do as you think, but as you start by reading with the camera in hand you will later thank me, saved money.
    As for lenses, it is better to buy less often and better. Try to choose bright and sharp glasses.
    Personally, I have more experience in Nikon and I don't know Canon lenses, but the rules are the same.
    Take your time shopping, read on some forum. The gunners probably have theirs too.
    Don't make mistakes right from the start. A typical error of inexperience is e.g. buying a long zoom.
    Much better exposures, though not all, can be done from a wide angle.
    I go on vacation, when I visit a lot, I take a lens with focal lengths of 17-55 and that's enough for architecture, landscape and typical memorial photos of family and friends.
  • #4 16279897
    gabik001
    Level 37  
    Help: 305
    Rate: 418
    If you ask so I will answer. Buy a short 18-55 to start with and learn. Learn a lot, take photos like a colleague above, until you get to what you need. Each of us started and did not know what would be needed until he did it himself. He advised me, e.g. 16-35 f / 2.8 L and this is a good lens but it is not cheap. You don't need grazing to learn.
  • #5 16280091
    cyctrus741
    Rate: 12
    Do you have any specific model in mind?
  • #6 16280114
    krzysztofh
    Help: 101
    Rate: 937
    Colleague gabik 001 after all gave you a specific model, just do not be scared, because it costs so much to almost three EOS 1300D.
    I have the impression that you do not draw conclusions from the advice given. Taking good photos can not be grasped in a week reading forums and watching videos on the net. You need a bit of self-denial, unless it is only about ill-considered pics of the family, but for this you just need any machine.
  • #7 16280123
    cyctrus741
    Rate: 12
    I will take photos mainly with my family, landscapes, photos at night. I wish they were good quality pictures. I certainly won't buy a lens for a few thousand.
    krzysztofh
    Help: 101
    Rate: 937
    For photos with family and landscapes "without a drink" is enough with the lens you have. For better quality photos, especially without distortion and sharper images, there will be no better glass. There will be no madness with night equipment with this equipment. To make something sensible at night, you must have a tripod. Note that night images start with an exposure time of 1 second (before dusk) to even 30 seconds.
    You can't do anything without a tripod.
    scotch
    Help: 78
    Rate: 148
    What would "exacerbate the situation": I studied photography at Zenith TTL, 122, 12 xp etc. It is known to limit 36 photos. Each frame must be well thought out and well exposed. Now we have digital cameras and an instant photo preview. Once you had to develop a film, make a print, etc. ... Replacing the lens alone was a waste of time. Now the camera does 99% of the work for us. However, the 1% remains, i.e. choosing lighting, focal length, composition of the frame and so on. As I wrote above, I have a Cannon + adapter for lenses with M42 thread. Now I am "sick" of the tripod and it is good to keep the old 1000 mm Mada lens in the USSR. Returning to the topic: I advise a colleague to get to know the camera, that is, to change its settings without error and in the dark. It is a pure technique but without any threads from further adventure. Later, composition of the frame, etc. stuff. This is the beginning. Later career or photos to the "drawer"
  • #10 16280903
    cyctrus741
    Rate: 12
    Thanks to everyone for help and extensive explanations.
The discussion revolves around selecting a suitable lens for the Canon EOS 1300D within a budget of PLN 1300. Participants emphasize the importance of understanding personal photography needs before making a purchase. Recommendations include starting with the standard 18-55 mm lens for general photography and learning, as well as considering the 55-250 mm lens for telephoto needs. Users advise taking time to practice photography and suggest investing in a tripod for night photography. The consensus is that quality lenses are essential for achieving better image quality, particularly for landscapes and family photos.
